It is currently Tue May 21, 2013 12:18 am
 Post subject: Random Slowdowns.
PostPosted: Wed Jun 27, 2012 9:11 am
My PC has been randomly freezing and slowing down doing the most simple tasks, like opening a folder or sending a text file to the recycle bin, browsing Facebook(shock wave flash plug-in also becomes unresponsive from time to time). Sometimes the hole system just becomes unresponsive for minutes.
I thought it was a windows problem, so I formatted the HDD and installed windows. But the annoying behavior persisted even after the fresh install.
My Specs:
BIOSTAR Group A880GU3
AMD Phenom II 819 4x @ 2.60
8GB ram
windows 7 ultimate sp1 64bits on a 1 TB HDD
another 1TB HDD for storage
No graphics card yet
Extra fan
What do you think this might be?
 Post subject: Re: Random Slowdowns.
PostPosted: Wed Jul 04, 2012 4:37 am
Did you install the chipset drivers that came with the board?
PostPosted: Wed Jul 04, 2012 5:40 am
Some common causes are heat and failing power supply (PSU).
