It is currently Sat May 25, 2013 6:14 pm
 Post subject: Help - voltage level for i5 3570k @ 4.1 Ghz
PostPosted: Mon Jul 02, 2012 4:26 pm
Just a week after building my first system, I'm already OCing it... :roll:
Specs:
Intel Core i5 3570k
CM Hyper 212 evo
Gigabyte Z77 UD5h
Corsair Vengeance 8GB 1600mhz
nvidia GTX 480
I've been using these guides as a reference:
http://www.maximumpc.com/article/features/maximum_pc_essentials_ultimate_bios_tweaking_guide
http://www.overclock.net/t/1247413/ivy-bridge-overclocking-guide-with-ln2-guide-at-the-end
I built this machine for gaming purposes, so I'm mostly OCing for fun and bragging rights. I'm aiming for 4.1 Ghz. I don't want to roast my new hardware though!
I started by lowering the vcore voltage to 1.1 from 1.185. Prime 95 displayed an impressive 10C temperature drop to 55C max, according to CoreTemp, after 30min. I then disabled turbo boost and the C states, thermal monitor and EIST and gradually worked my way up using the multiplier to 4.0 GHz, where upon starting Prime 95 I got the dreaded BSOD.
BSODs are scary- did I do any lasting damage to my PC? I cleared the CMOS and the machine does boot to Windows, but I'm still a little phased. If you still think my machine is OK, what voltage level/ other settings should I set for this OC?
Thanks for the help.
 Post subject: Re: Help - voltage level for i5 3570k @ 4.1 Ghz
PostPosted: Mon Jul 02, 2012 7:35 pm
http://ark.Intel.com/products/65520/Int ... o-3_80-GHz)
then go to datasheet volume 2 for voltages.
See: http://www.bit-tech.net/hardware/cpus/2 ... u-review/8
PostPosted: Tue Jul 03, 2012 8:25 am
I think my biggest question is "is instability from undervolting damaging my CPU?".
PostPosted: Tue Jul 03, 2012 8:29 am
BSODs and rebooting are a way of life for the OCer or Under-OCer. I can't see how under-volting would hurt anything; it never has for me anyway, YMMV.
Users browsing this forum: btdog and 2 guests
