It is currently Wed May 22, 2013 11:34 pm
 Post subject: Need help with gtx 670!!
PostPosted: Wed Jun 13, 2012 2:53 pm
Hello Guys,
I recently purchased a evga gtx ftw 670 from newegg last month, i recieved the card a week later, installed and downloaded the most up to date drivers. I then restarted the system, loaded windows to desktop then Red Screen, I called tech support they gave me a RMA. Today, I recieved my replacement card, installed it booted up windows red screen again... Im running no gpu monitoring software.
My spec as is follows
i5 2500k
hx 1050 corsair psu
asus p67 sabertooth
 Post subject: Re: Need help with gtx 670!!
PostPosted: Wed Jun 13, 2012 3:16 pm
Red screen as in the screen is tinted red?
I suppose you've checked the cable/monitor?
PostPosted: Wed Jun 13, 2012 3:35 pm
yes indeed I have, the screen is solid red
PostPosted: Fri Aug 17, 2012 10:41 am
Why didn't you download/install the drivers that came with the card. THEN update to the latest drivers.
I haven't needed to update the drivers on my card forever. I think the mistake was not doing what you were supposed to and installing the drivers that came on the cd that came with the vid card.
PostPosted: Fri Aug 17, 2012 11:18 am
Did you:
Uninstall the old driver first, say no to reboot then delete the video driver folder and empty the recycle bin?
Download, install and run the registry section of Ccleaner? That will clean out any entries left over by uninstalling the old driver.
Reboot, cancel the pop-ups, then install the new driver?
If you didn't that may be why the driver is corrupt and has a red tint to it.
PostPosted: Sat Sep 29, 2012 6:29 am
Folding for Elena
Folding for Elena
Just a few simple questions first
what were you running before this card?
do you have a power supply able to handle a card like this?
if you have some craptastic PSU that came with a 30 dollar case, I would check into that.
Were you running on board video and put a card in? Did you make sure the PCI-E slot was clean of dust and debris? you would be amazed at the crap I have cleaned out of systems. IF you had on board running before you may need to hit the cmos and make sure its set to auto to detect if you have a card or want to run on board.
There are lots of things that can go wrong and you really need to give a better idea of your situation.
When you go back to what ever your video source was before does the system run properly?
I'm going to assume it does. This would rule out bad video cable connections or bent pins?
Seriously, any nvidia driver would get minimal function out of that card. I'm personally leaning towards your power supply as insufficient power to run this card.
I had that happen to me when I went from dual GTX 260 OC's to dual 570s
looked like the same amount of power needed but the PC Power an Cooling 750 choked on it. Had to step up my game to a top tier power supply.
PostPosted: Sat Sep 29, 2012 10:44 am
I would certainly think that the corsair 1050 psu that he posted he was running would be sufficient to run two of those cards let alone just one. I also wonder what he was running before.
PostPosted: Sat Sep 29, 2012 2:32 pm
Folding for Elena
Folding for Elena
odd I dont recall seeing that when I posted but it was on a 4" screen lol
yeah that should pull it off
