It is currently Fri May 24, 2013 5:11 am
 Post subject: Win7 can't but XP can?
PostPosted: Wed May 09, 2012 8:18 am
I am having a weird problem with the internet over where I am at. My mom and sister flipped out that there was no internet. I came down did the unplug routine and the computer showed that it has a strong connection to the router. Despite of that, it still wouldn't connect to the internet. I did happen to noticed that it is the Win7 compy's that have this problem, the XP's act like there is nothing wrong and I don't know about the exchange student's macbook.
I had already unplugged for up to 10min and that didn't fixed it. I went to check out the coaxial, there're fine. Entered the IP address i.e 27.64.17.100 (don't try it, it could be a bad place). I also checked the drivers for the WUSB54g v.4 drivers, they say it is working properly. Is there anything else I can do?
 Post subject: Re: Win7 can't but XP can?
PostPosted: Thu May 10, 2012 3:04 pm
Bit more info re your broadband / internet connection and how u connect it in XP and how u connect ur Win 7 box/laptop?
PostPosted: Fri May 11, 2012 4:22 pm
Sounds like you have a virus on the win 7 pcs. Try running Smitfraudfix, Combofix and install, update and run Malware bytes in Safemode with Networking. If you have a virus this should get rid of it. Don't know nothing about Macs and don't want to. :wink:
PostPosted: Sat May 12, 2012 3:34 am
Formate the whole hard disk .try to set up win 7 then .
hope the problem will be solved .
If don't wait for win 8 . It'll coming soon
PostPosted: Sun May 13, 2012 3:16 am
i am new here ...i have already in this problem...so i need help in this problem ...
please help me...softology i work this line but nothing....
i need more help
PostPosted: Sun May 13, 2012 7:14 am
I think something has gone wrong with one of your pc's registry. Try downloading windows essentials, check your firewall as well and ensure pc is virus free
PostPosted: Sun May 13, 2012 5:51 pm
Hey fixed it a few days ago, bought a new netgear router wnr2000 and apparently it doesn't get along with win7 for some reason. Did some research on the forums and found out I need to simply change the SSID. Problem solved.
PostPosted: Mon May 14, 2012 11:37 am
For those who can't be helpful....Steve....let's try baby steps. Unplug the modem and router. After about 30 sec or so plug in the modem and wait for the lights go come back. Now plug in the router. See if you have internet connection. If not wireless check hard wired.
- Still no connection. Try a ipconfig / release then renew
- run ipconfig and see if you are getting an ip or a 169.254.x.x address
- Check device manager for any errors on the NIC cards
- Checking for malware is not a bad idea but check the basics first.
if you are pulling an ip then you could be infected but not unnecessary.
PostPosted: Mon May 14, 2012 12:09 pm
Flipper, he has connection on his XP machines on the same router, that is why I suggested he may have a virus blocking his connection on the win 7 machines.
PostPosted: Tue May 29, 2012 8:09 pm
flipper thanks bro very very much ....
PostPosted: Sat Jun 02, 2012 6:23 am
Hello! I am having problems when installing programs for my laptop (Win7), when I tried to install in our desktop comp (win xp) it was successfully installed. I have also tried fixing the compatibility issues, but then it still didn't work. How can I troubleshoot such probs. Thank you so much.
PostPosted: Sat Jun 02, 2012 4:20 pm
thomasallen,
You should have started a "New Topic" using the button next to "Reply" to ask your question, that way things don't get confused when answering the person that started this thread.
