It is currently Sun May 19, 2013 4:05 pm
 Post subject: Water Chiller
PostPosted: Sun May 27, 2012 5:50 pm
I've been looking for a cheap and affordable way to use a water chiller to oc my rig. I came across this (http://www.novatecproducts.com/iceprobe.htm)and I'm wondering if I can use it. Honestly, it seems too good to be true to me. It doesn't use a compressor so I don't have to worry about the longevity of the device, it comes with a controller for an automatic on/off cycle, and it consumes a relatively low amount of power. What are your thoughts on it?
 Post subject: Re: Water Chiller
PostPosted: Sun May 27, 2012 6:05 pm
The only thing you have to worry about a TEC cooler is the fact it can chill below ambient temperatures, which means you run the risk of condensation.
PostPosted: Sun May 27, 2012 6:14 pm
I plan to get neoprene foam or something similar to that to insulate the mobo and other stuff.
PostPosted: Sun May 27, 2012 9:03 pm
Are you sure that's ESD safe?
PostPosted: Sun May 27, 2012 10:27 pm
Neoprene sheets are sold at frozencpu so its a pretty safe bet that its ESD safe.
PostPosted: Thu Jun 14, 2012 1:14 pm
If a lot of air is moving inside the cabinet, the condensation problem is mostly going to come after the computer is shut down, I think.
