It is currently Tue Jun 18, 2013 2:18 pm
 Post subject: Whats that sound
PostPosted: Fri May 25, 2012 7:09 am
So when I was installing my cpu it made a sound like it was scraping across the pins... is this normal.
 Post subject: Re: Whats that sound
PostPosted: Fri May 25, 2012 7:45 am
If it's an LGA type processor, probably since a tale tale sign one has been installed are markings on the pads.
If it's a PGA type processor... I'd check the pins.
PostPosted: Fri May 25, 2012 7:51 am
LGA Proc so it is a normal sound...
