It is currently Tue May 21, 2013 4:33 am
 Post subject: Remove One Note
PostPosted: Tue May 01, 2012 8:52 pm
I do not want OneNote to keep appearing on the taskbar whenever I reboot my PC. It is very annoying. Can someone pls help? I have tried some tips online but I cannot seem to fix it.
 Post subject: Re: Remove One Note
PostPosted: Wed May 02, 2012 9:04 am
User either ccleaner and in the startup area delete it or disable it. Or you can use msconfig and just untick the box under the startup area. Reboot and you are done.
PostPosted: Wed May 16, 2012 5:42 pm
It worked!
Thanks so much!
