It is currently Sun May 26, 2013 12:55 am
 Post subject: NZXT 810 Switch Mod (Blue-Skull)
PostPosted: Wed May 02, 2012 4:15 pm
Well I was inspired by New platform that hit the market. Intel x79 chipset and LGA2011 CPU With its awesome Blue and Black Finish
The case theme is Blue, Black & White featuring The Intel Skull and a Large NZXT logo in Blue on the Back panel.
The Case that was perfect for the Build was the New NZXT Switch 810 just so many option to choose from its a perfect modder's case, ( My review is coming out tuesday) . Another set components that will fit perfectly into the theme, is The HyperX 120GB ssd from Kingston and Quad Channel Memory .
A big thank you to the Sponsors
let take a quick look at the NZXT Switch 810 Case
Such a clean looking case
You can tear down to the Bare Frame with ease.
One of the first things was to disassemble The front and top cover
No going back now !!!
 Post subject: Re: NZXT 810 Switch Mod (Blue-Skull)
PostPosted: Wed May 02, 2012 5:15 pm
Maybe i should try to take the black marker off and just put it back together?
Anybody have any glue?
Its going to take forever to file this down?
Done!!!!
I eyeballed that one about right!!!
And the front
PostPosted: Thu May 03, 2012 9:11 am
Oh what did you do this weekend? Ehh Cut a Intel Skull out of Liqiud Resin.
Dont mind the Buck teeth, I had to go look to see how many teh Intel skull had 8
PostPosted: Thu May 03, 2012 9:43 am
Just waited for the Paint to Dry today and snap a few more photos.
Prep Work using 400 Grit sand paper
Automotive refelective base coat
Chromoly Finish ? nah
Metalic Blue
matching it up, will soon be getting rid of teh chevy symbol :)
Nothing is secure yet, but i like what i am seeing so far
Like!!
A few more spots to smooth out
A nice up close look This piece is almost done :)
Thank you for looking
A few more pics testing out the looks of a 120 Enermax Vegas Trio Fan , Probley going with the 140's
Bawls!!!!
I am a happy guy
Again a big thanks to the NZXT,Intel and KINGSTON Supporting my modding addiction
Kingston HyperX
And Intel
PostPosted: Thu May 03, 2012 9:44 am
Small Update more to come this week, order White acrylic and sleeving, still need more watercooling supplies and lighting.
2nd round of paint , smooth down with 400 grit !!!!
Almost forgot these lol ,
Sanded and primed
Ask my awesome wife if she could make me some letters about 5 " tall using the cricut
Not going to use the font but can use them to make a outline
back panel layout
you ready to dance old friend
Still trimming
I am testing my idea paint the back side of the N
work on the back lighting
need some more polishing :) and to hook of the leds behind
Thanks for looking
Another weekend another couple of days to mod!!!!
Work on the skull led to get them that glow effect, first i needed to route out a spot for the eyes
The cut the piece and Sand
Done!!!
now time to test it out
I like it
Wow a big box came in
made a few cuts
Fits very well, My goal is to make a one piece interior cove rthat can easly pull out
you might also see what else i am working on in the pick as well
its starting to take shape, re doing the back piece to the rom bays, that was a scrap piec that almost fit.
Thanks for looking !!!!
PostPosted: Thu May 03, 2012 9:45 am
Wow, After 3 lan parties and Pax east I was able to get the ball rolling again.
First off like to thank my Newest Sponsor EK WaterBlocks For Thier amaizing Cooling Products, I have used Thier GPU water blocks before and amaizing Stuff.
I will go into more detail, When i start installing The Products
Do you rember when I cut these out
Time to attached and light it up!!!!
Ok this was a bad idea
better
Added the NZXT led kit
need to fix the Bleed through but diggin the effect
Enjoy
Thanks for looking
Added The watercooling For The cpu, STill waiting for the GPUs :(
Top EK XTX360 Rad
EK Supreme HF
EK-BAY SPIN Reservoir
Overall Very impressed how this build is turning out.
Teaser pics on the way
PostPosted: Thu May 03, 2012 9:46 am
Testing the Lighting to see how it looks of the interior side panels.
Enermax Vegas Trio Blue
Cant wait to finish Sleeving ( the final build you may only see like 5 connections)
Turned the vegas Trio to White loving it !!!
