It is currently Tue May 21, 2013 4:09 pm
 Post subject: oc'ing the 2500k
PostPosted: Sun Apr 29, 2012 12:05 pm
Ok here is the deal I just bought modern parts and I'm not used to this whole turbo thing. I also don't get when I check cpu frequency I see like 4200+ but on post I see 3412. I used to run my old e6750 rig about 1GHz over stock and I didn't have a massive cooler like this rig has. I'm a little confused. I would like some help in where I'm going wrong and what I should believe.
Fractal Arc Midi case (great case btw)
Asus P8Z68-v LX (could be better but had to save money somewhere)
Intel i5 2500k
Cooler Master Hyper N520
Crucial HX650w
Crucial 2x4GB XMS3 1600
ATI 4500 series vid (wish I had better but oh well)
WD 150GB raptor boot and 320GB caviar and a cheap LG optical
Any help I can get would be appreciated and if you feel like you want to donate a vid card for the cause feel free...haha
 Post subject: Re: oc'ing the 2500k
PostPosted: Sun Apr 29, 2012 12:10 pm
Turbo boost is Intel's "automatic overclocking" scheme where if some cores aren't being used, it shuts them down and overclocks the others.
PostPosted: Sun Apr 29, 2012 2:34 pm
ok then...how do I know where I'm at? I'm assuming then that individual cores can be clocked separately? What can I use to see what my parts are doing?
PostPosted: Mon Apr 30, 2012 12:59 pm
You don't touch Turbo Boost, you tweak with the multipliers. And since I didn't opt for a 2500K, I don't have experience here. But there should be plenty of overclocking guides on the internet. A Google search came up with this one first: http://www.bit-tech.net/hardware/cpus/2 ... i5-2500k/1
And also http://www.anandtech.com/show/4083/the- ... 0-tested/3 for good measure.
PostPosted: Tue May 01, 2012 7:35 pm
ok I'll check them out...thanks
