It is currently Sat May 25, 2013 10:21 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: Best Anti Virus for PC Gaming
PostPosted: Thu May 12, 2011 1:26 pm
Whats the best anti virus for PC gaming ?
 Post subject: Re: Best Anti Virus for PC Gaming
PostPosted: Thu May 12, 2011 7:07 pm
for a paid AV i would have to say ESET NOD32 hands down blows them all out of the water.
every time Maxpc does a Anti Virus show down ESET always gets a 9 Kick Ass award.
i have used it just recently and as always its super light on the resources.
as far as free AV i would have to say that Microsoft Security Essentials is very decent aswell.
PostPosted: Sun May 15, 2011 1:33 pm
I have been using free Avira Anti-virus with Malwarebytes as a companion and free Zonealarm for my firewall and have had no problems.
All are free, work well for me and I play a lot of games online.
PostPosted: Sun May 15, 2011 1:46 pm
Microsoft Security Essentials is free aswell..just sayin
PostPosted: Sun May 15, 2011 2:52 pm
Yup, used it on a few machines myself and it works fine also.
PostPosted: Tue May 17, 2011 8:17 am
I use Microsoft Security Essentials too, never had a virus or malware issue.
PostPosted: Fri Jun 10, 2011 2:54 pm
Recommend Kaspersky. Gamer friendly
PostPosted: Mon Nov 14, 2011 1:19 am
I use ESET Nod32 and it works good for me until now.
PostPosted: Sun Nov 27, 2011 11:27 am
currently im useing norton anti virus 2012 and no issues so far its not free but i havent been blocked yet from any game yet
PostPosted: Sun Nov 27, 2011 2:04 pm
I would also recommend kaspersky but have herd great things about eset
PostPosted: Sun Nov 27, 2011 4:20 pm
I'm gonna have to agree with Nasty here. Avira and Malwarebytes is a solid free security solution. I've used MSE plenty of times, but Avira is better. The new version of MSE currently in beta looks very promising though. SuperAntiSpyware I think is even better for malware these days. Windows 7 firewall is more than sufficient if you don't already sit behind a hardware firewall.
PostPosted: Fri Feb 03, 2012 4:39 am
I think MacAfee is perfect antivirus for any gaming PC. I am also using this from many years and for me it’s the best antivirus that I can suggest you.
PostPosted: Fri Feb 03, 2012 1:36 pm
Mcafee will slow your system to a crawl, it was also rated #4 out of ten in Max Pc. I use Microsoft Essentials and it works just fine and does not slow my system down. I am a heavy gamer and it doesn't interfere with gaming in any way at all.
PostPosted: Tue Feb 21, 2012 10:50 pm
I recommend you to use avast antivirus. the main reason is it's free to use. It's featurs are good to kill trozzan viruses. You can also try avira,avg, Norton bt Avast is the best.
for more info click onto the link:
http://www.techyv.com/blog/avast-antivirus-software
PostPosted: Fri Mar 02, 2012 10:41 pm
I suggest you the Avira Antivirus Premium 2012 this is the best one i have tried it..
PostPosted: Fri Apr 27, 2012 8:55 am
Has anyone here had a bad experience with MSE ?
Has it failed in any respect ?
PostPosted: Fri Apr 27, 2012 10:10 am
No problems at all so far and I have been using it for a year. I also installed it on my friends business computers and they are very happy as well. I use Malwarebytes to fight maleware along side of MSE on my computers and friends and families. I always uninstall Nortons and McAfee....junk in my humble opinion.
PostPosted: Fri Apr 27, 2012 10:12 am
http://www.av-comparatives.org/en/compa ... ry-reports is a good read. ESET and some others won on low-impact if you care about that. Otherwise Kaspersky won overall.
I still use MSE. It hasn't given me problems. I also use a paid version (it's only $30 one-time) Malwarebytes Anti-Malware in conjunction. However I don't like Anti-Malware blocking websites willy nilly. I had to turn that feature off. It doesn't ask if you're sure if you want to go to that website, it basically makes it so you can't access it.
PostPosted: Sat Apr 28, 2012 7:13 am
In what ways is MSE inadequate ?
What advantages do the non-free AV programs, like Kaspersky, have over it ?
PostPosted: Sat Apr 28, 2012 7:24 am
Anti-virus programs all have their flaws, not one of them can protect you 100%
Free anti-virus programs work just as well as the paid versions, the only difference I can see is the paid version runs all the time while you have to manually run a scan with the free versions (this is why the paid versions usually slow the computer down). MSE runs all the time and is not a resource hog like Nortons or MacAfee. As I said before, I use MSC along with Malwarebytes and have no problems with my pc in gaming or anything else.
What ever you decide to do, make sure you thoroughly un-install the old anti-virus program you are using...including all files and folders along with any registry entries or you will have problems.
