It is currently Sat May 25, 2013 4:50 pm
 Post subject: [help] core clock, shader clock, and memory interface
PostPosted: Mon Apr 23, 2012 7:29 pm
Both of the GPU's are the same chip but the first one has a lower core clock, shader clock, memory interface, and price. I am wondering if these difference will change the overall performance anough to warrent me spending the extra $60?
http://www.newegg.com/Product/Product.a ... 6814130770
http://www.newegg.com/Product/Product.a ... 6814127592
 Post subject: Re: [help] core clock, shader clock, and memory interface
PostPosted: Tue Apr 24, 2012 11:15 am
that is not all that is different, the cheaper one has less cuda cores, I would say spend the extra bucks myself. If you were to sli them it would likely default to the slower clock speeds and maybe turn off some of the cores in the better card.
PostPosted: Tue Apr 24, 2012 11:57 am
It's worth the extra money.
And dammit, now they have a GTX 560 SE? Why can't NVIDIA ditch suffixes?
PostPosted: Tue Apr 24, 2012 12:21 pm
even the memory bandwidth is different one is 192 bit and the other is 256 I do not think they will mix well together.
