It is currently Sat May 25, 2013 2:37 pm
 Post subject: Not showing video
PostPosted: Mon Apr 23, 2012 4:04 pm
I had just recently bought parts for a new build. I didn't have enough money at the time to buy everything so i decided to put parts i didn't buy ,from my old one. Such as the graphics card ,hard drive, ram.Thats it the rest of the parts are brand new. So i put together the computer and everything was fine , after i had put all the components in, the motherboard lit up like its supposed to.Then i pressed the power button on the case and it started up fine , but with no boot screen.So i rechecked everything , checked the plugs once again and still nothing.I put in a different card from another computer i had and still no video. I know for a fact that everything is compatible. Iv messed with it for multiple hours and i cant figure it out.
 Post subject: Re: Not showing video
PostPosted: Tue Apr 24, 2012 8:12 am
sawyer, can you please provide some specifics (on both the old parts and the new parts in this particular build)? It might help us to determine the cause of your problem. BTW, welcome to the forums!
PostPosted: Tue Apr 24, 2012 3:48 pm
Well some of my old parts had failed. Thats why i decided to upgrade but the new motherboard is a crosshair 4 formula, the processer is a amd fx6100 which both are brand new. The old parts i brought over was a gts 450 cyclone graphics card, coolermaster 750w psu, a hard drive ( not sure about the info on that) and 4gb of corsair ram. This is all installed in a new 600t case
PostPosted: Wed Apr 25, 2012 4:39 am
New
Cpu: amd fx6100
Motherboard: crosshair 4 formula
Case: corsair 600t
Old
Graphics: gts 450 cyclone
Psu: coolermaster 750w
cpu cooler: coolermaster hyper 212 plus
hard drive: dont know the info on it
ram: 4gb
PostPosted: Wed Apr 25, 2012 5:46 am
If you are getting no video on your new build, are you getting any beeps during the post that indicate any kind of memory errors? Try reseating your memory modules first. If that doesn't change anything, try running the new build with only one stick of memory (unless your 4 GB of memory is only one stick, that is) and see if that helps.
PostPosted: Wed Apr 25, 2012 2:12 pm
The FX6100 will only work with BIOS 3027, it is also listed on Asus' site as "Beta Support Only".
PostPosted: Wed Apr 25, 2012 2:47 pm
I wasnt getting a beep like your talking about pcstudent .I reseated the ram and nothing, left only one stick in and still nothing.
Nsvander how do i get different bios if i cant even start it up?
PostPosted: Wed Apr 25, 2012 3:13 pm
Some new ROG boards from Asus allow you to flash the BIOS with out a CPU installed, so you can run the newest CPU on an older board, not sure if this one does or not. The sure fire way is to get a lower end CPU that the board already supports (either borrow one, or buy one and return) flash the BIOS to the latest one, and install your new CPU. I am not sure if there is any other way.
PostPosted: Wed Apr 25, 2012 7:05 pm
yeah i have an older one , ill try it out
PostPosted: Wed Apr 25, 2012 7:27 pm
Just a thought. Did u make sure that you mount the motherboard to the case correctly. Did u make sure you put screws on all the holes on the motherboard? My brother in law had the same problem you've described.
PostPosted: Thu Apr 26, 2012 2:49 pm
yes carlidan i checked again , and its all standoffs with all screws in the motherboard, thanks for the concern tho (:
PostPosted: Mon Apr 30, 2012 3:57 pm
well i put a older amd processer and the computer still has no video
Users browsing this forum: boogeyman8 and 1 guest
