It is currently Wed Jun 19, 2013 12:01 am
 Post subject: How to round up and only up?
PostPosted: Sat Feb 11, 2012 2:32 pm
Hello,
I have a project where I need to calculate how many lifeboats I would need on board according to user input of amount of passangers and capacity of lifeboat.
Here is what I have so far.
*       Program:      K_D_Lifeboats.java
*       Author:       K. Dagenais
*      Student #:       0631794
*      Program:      CPA
*      Course:         INFO1150
*      Date:         11 févr. 2012
*      Description:   Program that calculates how many lifeboats are required on a given ship given the amount of people onboard
*                  capacity of the lifeboats
import java.util.Scanner;
public class K_D_Lifeboats
   public static void main(String[] args)
      // Create a Scanner object to read-in user inputs
      Scanner input = new Scanner(System.in);
      // Display a title
      System.out.println("Lifeboats Calculator\n");
      // 2. Ask the user to enter the following values:
      // a. The name of the ship (possibly including spaces like HMS Endurance)
      // b. The number of people on board the ship
      // c. The maximum number of people that can be carried by one lifeboat, assuming that all
      // the lifeboats on the ship are the same size
      // d. The actual number of lifeboats that are available on board the ship
      System.out.print("Enter the name of the ship: ");
      String shipName = input.nextLine();
      System.out.print("Enter the number of passangers on board of the ship: ");
      int passangersNumber = input.nextInt();
      System.out.print("Enter the maximum number of passangers that can fit in one lifeboat (same size boats): ");
      int maxPassangersLifeboat = input.nextInt();
      System.out.print("Enter the number of lifeboats that are available on board of the ship: ");
      int numberLifeboats = input.nextInt();
      double lifeboatsNeeded = passangersNumber / maxPassangersLifeboat;
      System.out.println("Here are the results...\n");
      if(passangersNumber > (numberLifeboats * maxPassangersLifeboat))
         System.out.println("A minimum of " + (int)lifeboatsNeeded + " lifeboats are required to rescue everyone on board of " + shipName + ".\n");
         double survivors = numberLifeboats * maxPassangersLifeboat;
         double casualties = passangersNumber - survivors;
         double percentageSurvivors = (100 * survivors) / passangersNumber;
         double tempPercentageSurvivors = percentageSurvivors * 100;
         int tempPercentageSurvivors2 = (int)tempPercentageSurvivors;
         percentageSurvivors = tempPercentageSurvivors2 / 100.00;
         double percentageCasualties = (100 * casualties) / passangersNumber;
         double tempPercentageCasualties = percentageCasualties * 100;
         int tempPercentageCasualties2 = (int)tempPercentageCasualties;
         percentageCasualties = tempPercentageCasualties2 / 100.00;
         System.out.println((int)survivors + " people (" + percentageSurvivors + "%) would be rescued.");
         System.out.println((int)casualties + " people (" + percentageCasualties + "%) would likely drown.");
      else
         int extraPassangers = (numberLifeboats * maxPassangersLifeboat) - passangersNumber;
         System.out.println(passangersNumber + " people (100.00%) would be rescued.");
         System.out.println("0 people (0.0%) would likely drown.");
         System.out.println("There would be room for an extra " + extraPassangers + " people in the lifeboats.");
This is what I get as a result when the program compiles.
Enter the name of the ship: the Admiral
Enter the number of passangers on board of the ship: 650
Enter the maximum number of passangers that can fit in one lifeboat (same size boats): 50
Enter the number of lifeboats that are available on board of the ship: 10
A minimum of 13 lifeboats are required to rescue everyone on board of the Admiral.
500 people (76.92%) would be rescued.
150 people (23.07%) would likely drown.
So far so good, I get the right percentage, and I get the right amount of lifeboats. But when I change to a number that gives decimals after the calculations, here is what I get.
Enter the number of passangers on board of the ship: 655
500 people (76.33%) would be rescued.
155 people (23.66%) would likely drown.
As you can see, I still get 13 boats there, even if it should be 14!! Now I tried several methods (Math.round() and Math.ceil(), casting, etc.)... Well, there's just so many things I tried as I hunted on the internet to find help. Nothing worked for me. If my lifeboatsNeeded's decimals are lower than .5, than automatically it will round it down. I just started my course in Programming, so I have just seen the Scanner class. I am at my wits end.
Please can anyone help me? Please?
 Post subject: Re: How to round up and only up?
PostPosted: Mon Feb 13, 2012 5:58 am
Welcome to the forum!
First off, I haven't done programming in years, but I think this is probably the most likely problem:
You define the variable lifeboatsneeded as a double instead of an integer. It should work if you keep it as an integer, keeping the values full whole numbers. If I remember correctly, it will round up even if you are below the .5 threshold for math rounding. So 4.1 would display the value of 5.
PostPosted: Tue Feb 14, 2012 7:08 pm
Jbaz has made two small mistakes .. not his fault, he is new to this section and hasn't programmed in a while.
First mistake:
We don't fix homework assignments. We do talk you through them, though.
You need to examine the logic of your program. At the very least, you need to identify where the problem lies.
The first line determines the number of lifeboats needed. Easy enough.
The second line casts the double as an integer. This, I assume, is your attempt to round the answer. This is also the solution that Jbaz offered.
So ... when java casts a double to an int ... what does it do? If you don't know the answer .. why are you doing it? Obviously, it isn't doing what you want. When you cast a double as an int, java simply discards everything after the decimal.
double smallNine = 9.1
int nine = (int) smallNine
Here, the value of nine is 9
double bigNine = 9.9
int nine = (int) bigNine
Here, the value of nine is .. also 9.
So, if you wanted to always round DOWN, you'd have your answer.
What you want to do, though, is always round up. The only time you don't round up is when you have a integer.
9.1 ... round up
9.5 ... round up
9.0 ... do not round
Thus, what you need to do is identify whether your value is an integer and, if so, leave it alone. If not, add one and discard everything after the decimal. I've already explained how to get rid of everything after the integer. What you need to do is figure out how to determine if your number is an integer. Hint: modulus.
PostPosted: Tue Feb 14, 2012 9:14 pm
Hello,
Thank you for kindly responding to my post. I must say though that whilst I was waiting for it to be approved for showing by the moderators, I was able to find the answer to my problem on my own. :) I came up with an answer that allowed me to keep the integer value, as I didn't enjoy seeing the .0 in my output.
I am very grateful to both of you for taking the time to analyse my program and giving me your ideas. It is very appreciated.
PostPosted: Mon Mar 26, 2012 10:40 am
First mistake:
9.1 ... round up
9.5 ... round up
It helped me with my rounding up problem (Health and division and non-integer problems in version 2.0 of my laser tag Arduino program). I never thought about it this way... Cool!
PostPosted: Tue Mar 27, 2012 11:54 am
Glad I could help. :)
PostPosted: Mon Apr 23, 2012 2:34 pm
Bitchin' Fast 3D Z8000*
Since the homework issue isn't a concern anymore, I'll provide a short terse answer. Whenever we want to "always round down" or "always round up", what we're actually attempting to accomplish is known as a floor or ceiling function. Also, we're not really attempting to "round" a number either. The definition for these functions is pretty straight-forward:
floor(x) = max(m in Z such that m <= x) and ceiling(x) = min(m in Z such that m >= x) ... where x is a real number and Z is the set of integers.
Thus, the floor(1) == ceiling(1) == 1 (for all x in Z).
Most programming languages have built-in ceiling() and floor() functions, but let's assume that we're working in an environment that doesn't provide these functions. How do we write them? Notice at the bottom of the Wikipedia article that older versions of Excel compute ceiling() incorrectly for negative values - ceiling(-4.5) is -4, not -5. Given the definition, the function argument is going to be a real number (ie a double floating-point value in most programming languages) and return an integer. I'll leave the implementation as an exercise for interested readers, but highly recommend that everyone spend at least a little time writing these functions in a few different styles of programming languages. They're a surprisingly good gauge of programming maturity and pretty typical of the type of programming problem that you can expect to see when interviewing at a Google or Microsoft.
