It is currently Sun May 19, 2013 2:07 am
 Post subject: Intermittant LAN connection issues
PostPosted: Sun Apr 22, 2012 5:47 pm
basically my hp dv7tqe keeps getting a limited or no connectivity dialog throughout the day, and the only current fix i have is to unplug the ethernet cable and plug it back in.
EDIT: just using wireless for now, hopefully building a computer in the next few weeks
 Post subject: Re: Intermittant LAN connection issues
PostPosted: Sun Apr 22, 2012 9:01 pm
I read your other thread, and am lost for a wired solution. Is there a reason you're using a cable? That laptop should connect fine wirelessly unless you're too far from your router. Could it be a weak/broken ethernet plug in the laptop? wiggle, wiggle.....
PostPosted: Mon Apr 23, 2012 5:13 am
FPS games dont like wireless connections
Users browsing this forum: Google [Bot] and 3 guests
