It is currently Fri May 24, 2013 1:06 pm
 Post subject: Project
PostPosted: Mon Mar 19, 2012 8:56 pm
Team Member Top 1000
I found old mid tower chassis with lots of potential. The front facial needs to be completely replaced. Has anyone worked with a company that does good 3d printing?
 Post subject: Re: Project
PostPosted: Fri Apr 13, 2012 3:16 pm
So, you don't want to mod stuff yourself?
PostPosted: Fri Apr 13, 2012 10:28 pm
The front plastic has a dated look. There is potential in it. I was considering having a company mill or print a model I would create. Everything else on the chassis would require a lot of cutting and etc. from me. Right now I am very busy with work and will have to come back to this later. I will probably just buy another tower to mod/build off of instead.
