It is currently Wed Jun 19, 2013 12:50 pm
 Post subject: Getting an Avatar
PostPosted: Thu Apr 05, 2012 11:08 am
Team Member Top 1000
How do you get an avatar in the MPC forums? I asked Number Six after reading a thread about it. Is that how it is still done around here?
 Post subject: Re: Getting an Avatar
PostPosted: Fri Apr 06, 2012 4:43 am
Team Member*
Team Member*
You should be able to now, at least I think you should. Six isn't doing admin duties anymore. check your user control panel==>profile==>edit avatar
If you don't have this option let me know I will do what I can.
PostPosted: Fri Apr 06, 2012 6:21 am
Team Member*
Team Member*
Try this one:
Quote:
If you cannot seem to upload an avatar, you might have better luck hosting the avatar on your webspace and then uploading the avatar by pointing to its location on the web.
-Six
PostPosted: Fri Apr 06, 2012 9:34 am
M.P.C. Forums U.C.P.: Options: Edit avatar wrote:
The avatar functionality is currently disabled.
Unfortunately it is still disabled for me. I am not able to upload or externally link an image right now. It will get all straightened out soon enough. Jipstyle said to consider asking someone else since Number Six no longer handles that. I would like your help very much so. Thank you! :D
PostPosted: Fri Apr 06, 2012 11:20 am
Team Member*
Team Member*
I have sent a request out for you we will see what we can do.
PostPosted: Fri Apr 06, 2012 11:22 am
Maximum PC Editor
Maximum PC Editor
Should be fixed.
PostPosted: Fri Apr 06, 2012 3:14 pm
nedwards wrote:
Should be fixed.
Thank you guys! :D Like the new look? ;)
Notice: The images I use are copyrighted. Do not reuse them. Thank you for your compliance.
