It is currently Sun Jan 25, 2015 1:21 pm
 Post subject: Malwarebytes and 8gb thumb drive 15 dollars
PostPosted: Fri Mar 30, 2012 3:23 pm
Folding for Elena
Folding for Elena
http://www.fatwallet.com/forums/hot-deals/1180619/
follow the directions
sign in to newegg
select the deal
add the code
get the best malware killing software cheap and a
8gb Kingston USB thumb drive
the software is worth 15 bucks for a lifetime version
the drive is worth 20 bucks
you cant loose@!
 Post subject: Re: Malwarebytes and 8gb thumb drive 15 dollars
PostPosted: Fri Mar 30, 2012 8:23 pm
the drive is worth 5$, 3 if you look hard enough.
PostPosted: Sat Mar 31, 2012 7:44 am
Folding for Elena
Folding for Elena
so a great copy of a great program
and a usb drive that is 8gb is not worth your time
glad to know it
the 5 dollar drives you will find
will not be corsair or kingston they will be some cheap slow ass
one you find in the dollar bin, but hey its your data man put it where you want
if you like the Dane/elec drives that they give away with a slurpee at 7/11
your good to go!
PostPosted: Sat Mar 31, 2012 7:55 am
I'm talking about a Kingston 8GB. The deal on the Malwarebytes sounds good, though.
EDIT: Linky to back me up: http://www.frys.com/product/5193356?sit ... ge:Sat_p11
This one's actually a Corsair, but Corsair makes good flash drives, too.
PostPosted: Sun Apr 01, 2012 9:06 am
Folding for Elena
Folding for Elena
well its a moot point most likely
pretty sure it was a that day only deal
malwarebytes is an AWESOME program
and a full retail life time install for 15 bucks is worth it
to any real power user like most max pc readers should be
even if you already have it installed( you do don't you?)
for a new build or one of our less educated "friends" that
call you when they have a tech issue, good to have LEGAL software
on hand to install when you need it.
PostPosted: Sun Apr 01, 2012 1:57 pm
^point
