It is currently Wed Jun 19, 2013 4:24 pm
 Post subject: CPUID false reading?
PostPosted: Wed Mar 21, 2012 10:26 pm
I was wondering if these reading are false because it sounds that I can't be that high.
cputin max high was 127 degress celcuis
auxtin max high was 127 degress celcuis
Did memtest to see if memory was at fault. Memtest passed.
Is it just software bug? Or should I be concerned.
Specs
processor: Intel core i7 2600k
mobo:asus p8z68 deluxe
Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Tower Case: Cosair Haf-x
video card: XFX Double D HD-687A-ZDFC Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
OS: windows 7 professional 64-bit version
If the is an other info u need. I will post it. Thanks for your suggestions and help.
 Post subject: Re: CPUID false reading?
PostPosted: Wed Mar 21, 2012 10:51 pm
False reading. It's a calculation based on a node that isn't on your build and is defaulting to it's Max range instead of voiding it. CPUz gathers basic information and has never been good with temps. CPU's don't report to sensors like a thermometer and will be a 1 or a 0 as far as a valid state it should be in for something as primitive as CPUz. It sees it's in a 1 state, it reports max temp.
The most hot component is 53C, so nothing can physically be more hot than that. 127C would make steam pretty easily and you couldn't touch the box. The "max" listing may as well be blind readings, as the min and average seem normal, yet far from this odd peak. Red Herring.
PostPosted: Thu Mar 22, 2012 1:50 am
Thanks Chumly for your quick response. :)
PostPosted: Thu Mar 22, 2012 2:30 am
Would RealTemp give a more accurate reading?
PostPosted: Sun Mar 25, 2012 10:12 pm
I wouldn't know. I havent used that software.
I know that because of cpuid's false readings. It also made asus's probe software give false readings. I was running both at the same time when probe gave the 127 degreess celsius temp on mobo temp.
