It is currently Tue Mar 31, 2015 3:43 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: GPU speed brag time!
PostPosted: Sat Dec 31, 2011 2:21 pm
Team Member*
Team Member*
I just thought since we have a CPU area maybe we can all post our GPU speeds! :D
    So far on a EVGA GTX560Ti SC:
    Stock: 900 MHz core clock
    1800 MHz Shader clock
    2106 MHz Memory clock
    OC: 1 GHz Core clock
    2 GHz Shader clock
I know the memory clock is the same but I'm working small increments at a time.
Validation link
 Post subject: Re: GPU speed brag time!
PostPosted: Sat Dec 31, 2011 2:24 pm
Wish I could OC my setup. But I have no head room in either cooling or psu. To do anything, I would have to step it up to LC and get a 1.2k psu; I have no desire to spend another $700 on this system.
PostPosted: Sat Jan 07, 2012 9:28 am
GTX 560 Ti It is this card, http://www.newegg.ca/Product/Product.as ... 6814125401
Alright, got everything running at at a voltage of 1.1 volts. Core is 970, Shader is 1940. Memory is at 2110.
This was done using MSI Afterburner. Folds like a beast.
Temps of 62 degrees in Celsuis with fans at 74 percent load.
PostPosted: Sat Jan 07, 2012 8:06 pm
Team Member*
Team Member*
Nice job!
PostPosted: Sat Jan 07, 2012 8:36 pm
Thx, tried to push it further, but it BOSD'd.
PostPosted: Sun Jan 08, 2012 11:44 am
    Stock: 900MHz core clock
    1800MHz Shader clock
    2106MHz Memory clock
    OC: 1KHz Core clock
    2KHz Shader clock
    2106 Memory clock
Dont you mean gigahertz? :D
PostPosted: Sun Jan 08, 2012 1:27 pm
Gtx 590s stock 612 core
Oc 720core 1900 memory
PostPosted: Sat Jan 21, 2012 12:58 am
Team Member*
Team Member*
giga what? Yeah I did, thanks Magnum!
PostPosted: Sat Jan 21, 2012 12:59 am
Team Member*
Team Member*
Nice job!
PostPosted: Sat Jan 21, 2012 3:07 pm
Should blame it on the Florida heat... its like always 130 degrees and 120% humidity there anyhow... lol
PostPosted: Fri Feb 03, 2012 12:42 pm
Folding for Elena
Folding for Elena
6870X2 = amazing card/performance for the money!
Stock = 900/1050
24/7 OC = 1040/1150
Benching = 1075/1225.
Validation = http://www.techpowerup.com/gpuz/n8nae/
edit: forgot to add this is a custom h2o loop as well and not stock voltage
PostPosted: Fri Mar 02, 2012 10:36 am
~shrug~ Don't remember the numbers off the top of my head, but I slid the sliders in catalyst all the way to the right ('cept the one for power) on my 7970... What's that, 1.1xx Ghz?
PostPosted: Sat Mar 03, 2012 12:15 am
Team Member*
Team Member*
We are spec junkies here, if you get a chance to looks at the numbers post them up so that we can see them. :D
PostPosted: Sat Mar 03, 2012 4:37 pm
3 EVGA GTX 470s
Stock 607 mhz
Core OC to 805 mhz and folding. Benched at 800. Vantage
All cards under water and fold from 40c to 50c.
PostPosted: Sun Mar 04, 2012 2:51 am
what blocks you running?
PostPosted: Thu Mar 08, 2012 8:15 pm
The Swiftech ones they did with EVGA. Not sure if they are the best but I got two of them for a good deal and managed to grab a third to complete the triplet.
PostPosted: Sun Mar 18, 2012 11:07 am
What happened to validations? I run at billions and billions and billions of Ghz, all at 38 Kelvin. Beat that.
What's this thread for? We really put trust in basic typing ability and skills to find the "Post" button with a cursor press? We need data, not just brags. Without, we learn nothing to educate each other. Otherwise...
Swiftech, because! Danger Den, Because! Oh no you didn't... Corsair because! Thus...nothing gained. I remember when we use to give data, not "oh no you didn't" bullshit. So I'm sticking with Billions and Billions at 38 Kelvin as the best ever here.
PostPosted: Sun Mar 18, 2012 10:49 pm
Team Member*
Team Member*
GPU-Z would be a good way to validate the results. Just saying... :D
PostPosted: Fri Mar 23, 2012 11:58 am
Something wrong with my vantage score?
And my pics are right here. :)
PostPosted: Sat Mar 31, 2012 12:16 am
Team Member*
Team Member*
Nope just adding other ways of validating.
