It is currently Thu May 23, 2013 5:18 am
 Post subject: HOW IS SO SLOW???? HELP!!!!
PostPosted: Mon Feb 20, 2012 8:37 am
SPECS:
OFFICE COMPUTER: THREE YEARS OLD
AMD SEMPRON 3400+ (1.80Ghz)
MOTHERBOARD- DELL
1.50 GB RAM DDR2
64.4GB HDD CAPACITY (SATA II- 3Gb/s) (PROGRAMS AND DATA)
VIDEO CARD INTEGRATED
PSU 350WATT
WINDOWS 7 ULTIMATE (32-BIT)
HOME COMPUTER: I BUILT THIS 3 MONTH AGO
AMD PHENOM II X4 965 (3.4Ghz)
MOTHERBOARD GIGABYTE 990FXA-UD3
8.0 GB RAM DDR3-1600HZ
500GB HHD CAPACITY (SATA III- 6Gb/s) (ONLY PROGRAMS)
2nd HDD 320Gb (SATA II- 3Gb/s) (ONLY DATA)
VIDEO CARD RADEOM HD 5550 1GB DDR3
PSU 550WATT 80PLUS
WINDOWS 7 PROFESSIONAL (64-BIT)
**MSCONFIG (SERVICES.MSC AND) ARE ALMOST THE SAME & HAVE THE SAME
SOFTWARE PACKAGE (WIN7, MS OFFICE, ANTIVIRUS, ACROBAT READER,)
WHY MY HOME COMPUTER (THREE TIME BETTER PERFOMANCE HARDWARE), BOOT-UP (WINDOWS 7) 3 TIMES SLOWER
THAN MY OFFICE COMPUTER?? :?:
I HAVE A CUSTOM BUILD HOME COMPUTER $680 (USD), OFFICE COMPUTER $399 (USD), NOW I HAVE DOUBLE THE PRICE, HALF THE PERFOMANCE!!!!
ANY HELP TO FIX THIS???
APPREC. ANY HELP
 Post subject: Re: HOW IS SO SLOW???? HELP!!!!
PostPosted: Tue Feb 21, 2012 8:50 am
I'd scan for viruses. That can really slow things down.
Is your shift key stuck? If you tap it repeatedly, it will usually unstick.
PostPosted: Tue Feb 21, 2012 7:28 pm
If you spent money on a custom build, you overspent if you're having performance issue on that machine.
PostPosted: Sun Feb 26, 2012 7:57 am
Boot up times are not really that important- it means you are loading up more stuff.
I'd say you will see a great boot up improvement if you could upgrade your home pc to a true sata III ssd, like a samsung 64gb 830 series-which is pretty cheap these days.
PostPosted: Wed Feb 29, 2012 10:18 am
Typical boot time for Windows 7 is 45 seconds from start to "hard drive stops doing something". If your home computer takes a full two minutes, you obviously have crap on your computer that's slowing it down.
PostPosted: Wed Feb 29, 2012 10:28 am
It depends. My Athalon x2 system takes about one and a half minutes to boot to the login screen, and about 5 minutes until when the hard drive stops doing stuff after login. It becomes usable about 20 seconds after login.
By comparison, a Core 2 Duo laptop I have takes about one minute to boot, and becomes usable 15 seconds after login. These systems are both clean and normal.
An i5 system I build is in between the two, time wise.
It really depends on the hardware.
PostPosted: Wed Feb 29, 2012 10:31 am
This is why I said typical... though I'd worry about you too. I had an T8600 laptop and it boot into Windows 7 usable within a minute or less. Did you do an msconfig scrub?
PostPosted: Wed Feb 29, 2012 10:56 am
It also depends what security you are running. Panda Security can slow your boots by 2 minutes, while ESET did closer to 30 seconds. I wouldn't worry about my systems, because they aren't using SSDs for the boot drive.
Users browsing this forum: dedgar, Google Adsense [Bot] and 0 guests
