It is currently Wed Jun 19, 2013 5:35 am
 Post subject: amd II x6 1055t core speed issue
PostPosted: Wed Feb 15, 2012 9:45 am
i have a amd phenom II x6 1055t four cores run at 2.8 and 2 run at 800mhz.. my mother board is m4a79 xtd evo the bios is up to date everything is stock settings i have no idea what to change to fix this problem or if there is a problem any help whould be great
 Post subject: Re: amd II x6 1055t core speed issue
PostPosted: Wed Feb 15, 2012 1:48 pm
I think they have on-board instruction in the CPU to throttle down if a core is not being used. It is a power saving measure.
PostPosted: Wed Feb 15, 2012 1:56 pm
yeah its werid casue icant overclock those 2 800 mhz cores to match the rest of the cores with turbov
PostPosted: Wed Feb 15, 2012 3:46 pm
They turn on when needed...which is almost never.
PostPosted: Wed Feb 15, 2012 3:49 pm
i see thanks :)
PostPosted: Thu Feb 16, 2012 5:23 am
Are you using win 7 or XP?
What does the bios read the cpu as...hex core or it doesn't know.
Is the motherboard an AM3 motherboard or AM2+ motherboard?
Did you update the bios?
PostPosted: Thu Feb 16, 2012 9:04 am
win7 bios sees it as a 6 core and bio is current
PostPosted: Thu Feb 16, 2012 11:05 am
Just wanted to make sure the processor was installed in the proper motherboard.
