It is currently Mon Mar 30, 2015 7:35 pm
 Post subject: No Swiffer sheets handy for case air filter. What do?
PostPosted: Tue Jan 17, 2012 7:14 pm
Million Club - 5 Plus
Air conditioner filter foam from the hardware store!
1. Here's Frankenbox IV in its natural habitat. (Feel free to ignore the DEC badge) Notice the open bay; instead of a FDD, I put my C: drive there to enable it to get cool air pulled over and around it. Also, the bottom of the front panel was cut away for better airflow.
2. Front cover removed, in all its ugliness. Note the massive 80mm PC Power & Cooling Silencer fan.
3. Et voilĂ . Air conditioner filter foam held in place by a total of 24" of solid RatShack 18 AWG hookup wire. Toolless removal, element cleaning and replacement!
4. Closeup of the empty bay cover. A piece of wire to hold the foam to the grille.
 Post subject: Re: No Swiffer sheets handy for case air filter. What do?
PostPosted: Wed Jan 18, 2012 1:03 pm
Gonna do this on my HAF912. Looks good!
PostPosted: Wed Jan 18, 2012 2:12 pm
wow... I threw that case away like 3 months ago... Been sitting in my attic since 97? Old pentium pro system.
PostPosted: Wed Jan 18, 2012 6:06 pm
I got the entire system for free... my public library tossed it. 600MHz P3, 10GB hard drive, MSI mobo. They didn't know how to take out the hard drive (hint: a Phillips screwdriver to undo the cage)... had everything but RAM. Got a 128MB stick from a friend for free. XP Pro fired right up. The old parts are stored in a box for emergency use :P
PostPosted: Thu Jan 19, 2012 3:29 pm
wait... what library? I just gave it to a library... If you open the door handle and look under the floppy disk bay, does it say JBaz?
IS YOUR MIND FREAKED!?!? lol
PostPosted: Thu Jan 19, 2012 6:02 pm
Amazing.
That would be a surprising coincidence.
My library uses Atom boxes for the workstations and old i3s for the librarians.
PostPosted: Thu Jan 19, 2012 6:22 pm
do you even know what I'm referencing? without googling
PostPosted: Thu Jan 19, 2012 7:03 pm
Sorta. I don't keep up with memes.
PostPosted: Thu Jan 19, 2012 7:49 pm
its not even a meme... its a pop-culture reference to a tv show...
If your going to replay, actually know something about it instead of just being completely ignorant and kill the joke.
PostPosted: Thu Jan 19, 2012 9:02 pm
I was commenting on the coincedence of your giving your system to the library shortly before Ovenmaster picked his up.
[/serious] (Maybe we should start putting in these handy tags... Without facial expressions I cannot tell a joke or sarcasm from a hole in the HTML.)
PostPosted: Thu Jan 19, 2012 9:36 pm
I can't tell you are being sarcastic (bad one if it is) or just completely oblivious, either way, its pretty stupid and moot at this point. Honestly, if you can't tell if that was a joke, then don't even comment in the first place dude...
seriously... I mean its pretty damn obvious.
PostPosted: Thu Jan 19, 2012 10:00 pm
I couldn't tell :p
I need facial expressions and body language to get some things. Vocal tones help too.
[/notjoking]
