It is currently Fri Mar 06, 2015 5:09 pm
 Post subject: I need help configuring a Logitech Joystick to newer games
PostPosted: Mon Jan 09, 2012 6:08 pm
I have been playing alot of games on my PCs eversince the mid 90s using a joystick.I know most people use either a game pad or a keyboard,but I am limited because I only have the use of my lefthand.
I ask the sales people at the stores I go to for games that support joysticks,I have purchased a few including " Halo 2 for Vista ,Doom 3,Fear 3 and a few others,none allow me to use a joystick.
I am extremly frustrated,I guess I'm destined to play Quake 2 untill I go to the great Gamer in the sky.
Any suggestion? I tried JoyToKey,that didn't help.
Please help me.
BTW I'm using Windows 7 Home Premium 64 bit.
 Post subject: Re: I need help configuring a Logitech Joystick to newer gam
PostPosted: Tue Jan 10, 2012 11:36 pm
Most games will support the Xbox 360 gamepad. It uses a different input API. Most people get around this by using a wrapper to translate to the new API. Look up "360 controller emulator" for how-tos. In the end, you will have to drop a few files into the game directory.
PostPosted: Thu Jan 12, 2012 11:26 am
like a rock - waitaminute, I AM a rock
I've used Xpadder before, but that was for two XBox 360 controllers so that I could play MAME games with friends on a PC. I haven't used it for anything but game pads so I'm not certain it'll work for your joystick but you can check out the forums. I don't think Xpadder was free at the time I got it though.
Good luck.
PostPosted: Sat Jan 14, 2012 5:43 am
Doesn't the Logitech Joystick software allow you to make "profiles" for games by assigning key strokes to the joystick?
PostPosted: Wed Jan 18, 2012 10:10 pm
how about something like this, http://www.newegg.com/Product/Product.aspx?Item=N82E16826100006
or this looks to be left handed http://www.newegg.com/Product/Product.aspx?Item=N82E16823126050 and includes a thumb joystick, might be a learning curve but should work with any game and give you one handed control.
PostPosted: Tue Mar 13, 2012 10:45 pm
for which game you want to to configure the joystick
