It is currently Mon May 20, 2013 6:54 am
 Post subject: Mointor won't wake up after sleep.
PostPosted: Thu Jan 05, 2012 3:19 am
Running Windows 7 Pro 64-bit system. My motherboard is an Asus z68 deluxe and graphics is an XFX 6870 card. Each time I wake up from sleep my monitor will not wake up from sleep mode. My system on the other hand does because I can hear the fans running. Do anyone has suggestion as to how to fix this problem?
 Post subject: Re: Mointor won't wake up after sleep.
PostPosted: Thu Jan 05, 2012 6:36 am
What brand and model of monitor are you referring to?
PostPosted: Fri Jan 06, 2012 5:02 am
It's an HP Compaq LA2205wg monitor.
PostPosted: Fri Jan 06, 2012 9:07 am
Million Club - 5 Plus
Did you try the latest drivers?
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_lang=en&h_client=s-s-r2515-1&h_cc=us&h_query=HP+Compaq+LA2205wg+22-inch+Widescreen+LCD+Monitor
What happens if you unplug the DVI connector and plug it back in after you have woke up the computer?
The only thing I have done and also finding on the net is disable sleep mode..
Hopefully someone has a better solution if you really want sleep mode.
GL
E
PostPosted: Wed Jan 11, 2012 12:03 am
Update your BIOS and check for waking PCIE settings.
PostPosted: Wed Jan 18, 2012 3:17 am
Just update my BIOS and it seems to fix the Sleep problem.
