It is currently Tue May 21, 2013 11:50 am
 Post subject: Help with Ripping DVD's
PostPosted: Thu Dec 01, 2011 12:57 pm
I'm going through and ripping all of my kid's movies onto an external HDD. I've been using DVD Fab, but it's not very reliable. About 1 out of 3 DVD's will just "stall" and DVD Fab sits there trying to read it.
What other programs can I use instead DVD FAB that would be more reliable? I have Win7 running on a i7 860 with a ATI 5870.
Thanks.
 Post subject: Re: Help with Ripping DVD's
PostPosted: Thu Dec 01, 2011 2:49 pm
Team Dino
Team Dino
DVDDecrypter.
n0b0dykn0ws
PostPosted: Thu Dec 01, 2011 4:33 pm
I'm getting some weird read errors with DVD Decrypt. Any other programs I can try?
I/O Error!
Device: [4:0:0] ATAPI iHBS112 2PL01 (D:) ATA
ScsiStatus 0x02
Interpretatio: Check Condition
Then several long strings of numbers follow.
PostPosted: Thu Dec 01, 2011 4:54 pm
I think the DVD's that are giving DVD Fab trouble is also the ones giving DVD Decrypt trouble. I'm wondering if small scratches of other blemishes is causing copy problems. (These are my kids movies after all.)
PostPosted: Thu Dec 01, 2011 8:17 pm
Check the discs closely for scratches. Whenever I use DVDFab and a disc can't be read, it's usually because it's too damaged ... and that takes some doing.
PostPosted: Thu Dec 01, 2011 9:01 pm
I used DVDShrink to rip DVDs. You can strip out anything you don't need making images smaller.
PostPosted: Sat Dec 03, 2011 9:04 pm
Team Member*
Team Member*
I have used Clone DVD and Any DVD and when I had a problem ripping a DVD they got the info for the DVD and the error file and fixed the problem then sent out a update to everyone. I know its not freeware but it is very worth it to me.
PostPosted: Fri Dec 30, 2011 9:34 pm
With an uberlight app of only 198KB, you can tie the two best free DVD apps together (Decrypter and Shrink) for a flawless rip each and every time with RipIt4Me.
