It is currently Thu Jan 29, 2015 4:42 am
Post new topic Reply to topic  [ 591 posts ]  Go to page Previous  1 ... 26, 27, 28, 29, 30  Next
 Post subject: Re: CPU speed brag time!
PostPosted: Mon Jul 18, 2011 11:11 pm
Million Club
Million Club
Update: My 4.5ghz OC was getting 15k PPD for about two WU's but I could not keep it up lol, was using refrigerated air ducted directly onto the CPU cooler. It currently gets 9600 PPD at 4.1ghz stable full time with 1.4volts, 200x20.5. :mrgreen:
PostPosted: Sun Jul 31, 2011 12:01 am
I'm inspired by you all. I will follow in your footsteps this fall when the weather cools down.
PostPosted: Thu Aug 18, 2011 2:33 pm
Million Club
Million Club
You could always get a better cooler and try again now...
I got my 4.5ghz on air: Cooler Master Hyper 212+ with 2 Scythe Ultra Kaze's (3000 RPM / 133 CFM) fans in Push/Pull.
Anyway, I'm out now. See you guys in the next Chimp Challenge or something.
I'll still check my PM's and such and maybe post occasionally.
~TheJake
PostPosted: Sat Sep 10, 2011 3:06 pm
Unlocked mult
PostPosted: Sun Oct 09, 2011 6:57 pm
Hey vistageek, You don't list your location in your user profile. With that overclock I am wondering, are you at a research station in Antarctica? I know, the unit is sitting in the shade just outside a window. The wind is 30 knots and the air temp is -40.
What kind of cooling are you using to get that overclock?
Of course those cores would be a lot hotter if you were running a Stanford SMP protein research folding ap. All cores would be running at 100%.
PostPosted: Sun Oct 09, 2011 7:51 pm
I didn't actually get my poor little Q6600 going that fast haha. One time I fired up Coretemp and that's what it showed, so I screenshotted it. I wish this thing would overclock like that :)
PostPosted: Fri Nov 04, 2011 3:34 pm
What kind of cooling should I use to prevent a power surge?
PostPosted: Sun Nov 06, 2011 10:02 am
Team Member*
Team Member*
You might try this in the help me buy help me build section of the forum it would be a better fit.
 Post subject: Re:
PostPosted: Sat Dec 24, 2011 12:41 am
Raven wrote:
I dont overclock, it's the work of Satan
Very well said. Check my usern to see my DRAM clocked to 11th cloud.
I have a custom dual motherboard rigged with two i7-980X ... megaclocked.
PostPosted: Wed Dec 28, 2011 12:10 pm
Intel 970 4.5ghz
Intel 930 4.2ghz
PostPosted: Wed Dec 28, 2011 1:10 pm
quick! everyone post up your most stable under-clocking numbers!
PostPosted: Fri Dec 30, 2011 11:24 am
Wrong place dude. Out for trolling, or are you really curious?
Here: .865V. That's your answer. Beat it or beat it.
PostPosted: Fri Dec 30, 2011 11:34 am
curious than anything since its hard to under clock than most people think since the chip needs a certain amount of power to have the logic gates working.
PostPosted: Fri Dec 30, 2011 1:32 pm
High k gates have helped out tremendously with regard to underclocking. Probably one of the most important innovations in x86 architecture. But to return to the speed conversation...
My i3 560 is @ 4.625Ghz. Anything faster than that and my RAM craps out. :(
Pushing almost 30fps in Unigine's Heaven DX11 benchmark. That's faster than my stock clocked i7-2600K was coupled with the same gear.
Not bad for a mini-itx rig. ;)
PostPosted: Wed May 02, 2012 4:57 pm
Ok heres a little on my first time oc.
FX 8150 8core @ 3913.05 (200.67X19.5)
CPU 32degrees
Im running max settings on MW2 with no lag
PostPosted: Wed May 16, 2012 3:52 pm
Overclocking is new to me as I have just now built my first rig with the real guts to do it.
AMD A8-3870k llano 3.0 Ghz OC'ed to 3.5 on Air (CM Hyper Tx3, Push Pull)
8 GB of Gskill Ripjaws X 1600 @ 1866
I also underclocked it, I guess because I was bored, any ways on stock voltage it would go down to 1.6, however undervolting the chip a bit got me to 1.2 then stopped. I'm to afraid to hurt it.
PostPosted: Thu Jun 14, 2012 11:23 am
PostPosted: Sun Jun 17, 2012 8:50 pm
I only have M350@2.27GHz
slow
PostPosted: Mon Jun 18, 2012 4:08 pm
Nothing great here, but it's way more than I've ever pushed for in the past.
Antec 900 case with 200mm top fan as exhaust
Gigabyte GA-990FXA-UD3 Rev 1.0 motherboard
AMD Phenom II X6 1055t 2.8GHz 6-core processor
Tuniq Tower 120 Extreme HSF with 80CFM 120mm fan added & alligned to blow warm air directly into the 200mm top exhaust fan
Was never able to get over about 3.1 to 3.2 GHz in the past... but durring my rebuild adding in 2 SSDs in RAID-0 & 16GB DDR3-2133 RAM, I upgraded the BIOS from F5 beta to F7 final. After getting everything set, I decided to try my hand at overclocking again.
Here's a little screenshot of my results :D
Been folding for over an hour, max temp 48C at 3.5GHz on air cooling! Not going to try any higher though. 700MHz OC is more than enough for me right now :!:
PostPosted: Sat Sep 01, 2012 4:55 pm
4.4GHz via the auto-overclock on an ASUS P8P67 Deluxe. i7 2600k HT on, Hyper 212+ push/pull.
Proof
