It is currently Mon May 20, 2013 2:13 pm
 Post subject: Netgear wndr3700v3 wireless router
PostPosted: Thu Dec 22, 2011 7:50 am
I recently purchased a Netgear wndr3700 wireless router. When I opened the box, I found the router was a wndr3700v3 model. Can someone tell me what the difference is between the v3 router and the previous ones?
Thanks in advance
 Post subject: Re: Netgear wndr3700v3 wireless router
PostPosted: Thu Dec 22, 2011 8:26 pm
I don't know specifically what the differences are, but usually it involves one or more hardware changes (chipset, change in flash/memory size, processor, etc.). In most cases, these are changes that shouldn't be necessary for the end user to know. The one reason you might need to know is if you intended to update the router w/ third-party firmware. In that case, differences in hardware could affect which firmware worked, if any at all. If you visit the dd-wrt database, it will often provide some details regarding those differences.
http://www.dd-wrt.com/site/support/router-database
