It is currently Sat May 18, 2013 5:24 pm
 Post subject: cFosSpeed or XFast LAN any good?
PostPosted: Sat Dec 17, 2011 12:09 am
I have xfast lan installed that came with my mobo. It's basically cfosspeed re-branded for ASRock.
Does anyone know if it really helps network speed? I do online gaming and some general internet things.
I probably don't know how to use it to it's full potential anyway. Also, I can't get any updates with out buying it.
I put Steam as a high priority program and it didn't seem to make any difference.
Should I just uninstall it?
Edit: Oh ya I have a pretty good internet. It's cable. I was wonder if it worked better on slower connections or something.
 Post subject: Re: cFosSpeed or XFast LAN any good?
PostPosted: Sun Dec 18, 2011 6:20 pm
If you have other people on your network then this program wouldn't be too helpful.
It's going to be similar to the "Killer" NIC reviewed here I imagine.
http://www.maximumpc.com/article/review ... ard_review
