This issue is really getting under my skin. This my be a little complicated but I will try to be brief. I have a wireless G router modem from verizon in the garage where the coax comes in. From there it does not have great range, and is only wireless "g". From the modem router I have a cat5e cable going upstairs where I have another wireless router. I used to have a linksys wrt54g upstairs, it stopped funtioning after about 2 years of flawless service. I looked into replacing it, but it was going to cost $60 to $70. Since getting the linksys I have added a couple of devices that can operate on an N network so I thought I would come into the present and get an N wireless router. I purchased an Asus RT-N16 to act as the wireless router and disabled the wireless transmitter of the verizon "g" router in the garage. As with the linksys I changed the asus IP address to 192.168.2.1, which worked fine for the linksys. I did this because the verizon router has an IP address of 192.168.1.1, which was the default for the asus. At first there was some kind of issue that prevented the asus from accessing the internet, but it finally took the new address. The kids kept turning off the power to the asus which ended up putting it into a recovery mode that it would not operate in. I returned it and got a replacement and set it up the same as the first asus, except that the power could not be turned off to it. It gave me an argument, just like the first asus, but then took the settings. It worked great for about a week. Then at random times the internet would not be accessable to my laptop or wife's e-reader but my daughters Kindle Fire got to the internet fine. Is there something wrong with my new asus router, the laptop ( and e-reader), or do I simple have a setting on the asus router wrong? I set it up as if it were the only router on the system. Do I need to change it so that it doesn't assign addresses? I have some wired gear connected to the verizon router and some connected to the asus. The asus is the only router transmitting. Please help this is driving me crazy.
