It is currently Wed May 22, 2013 10:01 am
 Post subject: Want to setup a CISCO CCNA home lab and need some help
PostPosted: Sat May 28, 2011 3:45 pm
Ok, so i want to set a a lab in my house to study for the CCNA exam. I already have a CISCO 2501 router and a CISCO 2610 router and three laptops. Should i buy a switch? If so how many and which models. My budget is limited (preferably the cheapest switch i can get by).
 Post subject: Re: Want to setup a CISCO CCNA home lab and need some help
PostPosted: Wed Jun 01, 2011 1:18 pm
Ideally you want at least 2 routers and 2 switches, but 3 of each is better. Of course more is always better, but the return on investment isn't that great after 3. For switches, the sweet spot as far as price/features is the 2950, which you can pick up for less than $50 on eBay. As far as routers, what you have is sufficient as long as there is enough RAM and Flash in them to run a decent enough IOS verison. You want at least IOS 12.2.
If you can't/won't afford any further equipment, download GNS3 (a free Cisco router emulator) and http://www.freeccnaworkbook.com. It will walk you through downloading and setting up GNS3 and then take you through exercises that will cover all of the CCNA exam topics. You can also get free remote access to a full lab at http://packetlife.net/ and at http://www.stubarea.net.
PostPosted: Mon Nov 28, 2011 12:57 pm
If you are still looking for information I would highly recommend:
http://www.networkworld.com/community/odom
I have been reading his blog for a while and have set up a CCNA/CCNP lab at work based on his articles. He lists exactly what to get as well as projected prices and recommended IOS to have running.
Hope it helps and good luck!!
PostPosted: Fri Dec 02, 2011 8:08 pm
sandeja1, Wendell doesn't really post there anymore, try his blog here:
http://ccnaskills.wordpress.com/
