It is currently Sat Apr 18, 2015 12:59 pm
 Post subject: Javascript HTML nightmare *rips out hair* SOLVED
PostPosted: Fri Nov 18, 2011 2:42 pm
I fixed the problem, it was dumb and had everything to do with arrangement and the fact I was using name="" instead of id=""
*facedesk*
 Post subject: Re: Javascript HTML nightmare *rips out hair* SOLVED
PostPosted: Sun Nov 20, 2011 1:14 pm
*facedesk*
Are you using jQuery? jQuery makes javascript so much easier. Here are tips for javascript and HTML:
- Seriously, use id over name. HTML id's are unique to the element, name is a deprecated feature (IIRC).
- Learn how the DOM tree operates. HTML is heavily dependent on DOM traversals. It's not as hard as you think and it'll make you quick on the draw when writing javascript.
- Use a nice framework like jQuery, suppose you have a textbox that you need to populate:
var d = document.getElementById("myTextBox");
d.value = 'Some value';
jQuery short hands this:
$("#myTextBox").val('some value');
jQuery is the future of javascript and it's worth learning. I use it pretty heavily in projects, it makes AJAX calls a LOT simpler.
- Learning Javascript is a must in web development, invest some time in learning it.
