It is currently Fri Jan 30, 2015 2:10 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: multiple copies of xp mode on one pc?
PostPosted: Sat Nov 12, 2011 6:47 am
I asked this a few months back, but can't find the answer on here.. so I aplogize because I need to ask again:
I have my laptop that has Win7 Pro 64-bit. Can I run multiple copies of XP Mode on this laptop, or am I limited to only one instance per machine? (I would only be running one at a time, but I want to have a few VMs with various configs).
 Post subject: Re: multiple copies of xp mode on one pc?
PostPosted: Sat Nov 12, 2011 9:10 am
perhaps using the browser search on the first page would give you some better results.
I recommend using your name.
PostPosted: Sat Nov 12, 2011 10:54 am
yeah, i guess i could have done that. was on my cellphone, which isn't great at surfing because of a freakin' tiny screen. but i will do that.
PostPosted: Sat Nov 12, 2011 9:38 pm
and you felt the need to ask that then??
PostPosted: Sun Nov 13, 2011 10:28 am
I was on my cell phone and google searches (and many websites) don't always display correctly and are hard to navigate. It's a problem with the phone itself because of the browser that is integrated into it. MaxPC is one of the few sites that actually likes to work. Google is fine, but half the time i can't see the results or when I got to a result, the page is written for a normal browser and it just gets messy. Plus, I wasn't at home... I was at a client's place and sort of needed a quick answer. But yes, I guess I could have googled myself on maxpc.
But, yes, I did find a very good article that discusses and shows how to do such a thing. It's a bit of leg work, but I guess for what I'm doing (just needing various configs for application and web site testing) it beats buying a few copies of XP, which are still somewhat expensive in my view.
PostPosted: Mon Nov 14, 2011 4:24 am
viewtopic.php?f=6&t=124504
