It is currently Sun Mar 29, 2015 11:55 am
 Post subject: I want to clone an entire computer to 6 others (image soft?)
PostPosted: Thu Aug 25, 2011 1:57 pm
I basically want a computer cloned to 5 or 6 others. Windows, Office, Network settings, etc. What is the best way to do this?
Especially, how do you handle valid windows keys? I have about 20 keys to use. (MS Technet subscription)
 Post subject: Re: I want to clone an entire computer to 6 others (image so
PostPosted: Thu Aug 25, 2011 2:12 pm
Are these computers all exactly identical from a hardware perspective?
PostPosted: Fri Sep 09, 2011 10:23 am
this has been covered before, the technet only allows installation of software for test purposes only. if you think you can use this software as a permanent install, you are wrong, you must purchase the license for each install separately or be in violation of the terms of service.
PostPosted: Fri Sep 09, 2011 11:36 am
That is true.
