It is currently Thu Jan 29, 2015 7:44 pm
 Post subject: Ubuntu 11 new install, slow, slow, s l o w internet.
PostPosted: Thu Jul 21, 2011 10:39 am
I just installed Ubuntu 11 on my Acer timelineX 5820T, core i3, 2.4ghz, 4gb ram, 250gb hard drive laptop.
I installed it side by side with Windows 7.
After the install Ubuntu works really, really slow on the internet. Internet speeds of like only a few kb per second. It took about 10 minutes to download a 21.2MB file whereas on Win7 I'd be done in a minute or two. Also seems to run much slower as well...
Suggestions? I am new to Ubuntu and Linux so keep that in mind :D
 Post subject: Re: Ubuntu 11 new install, slow, slow, s l o w internet.
PostPosted: Thu Jul 21, 2011 2:31 pm
So exactly what you are basing this alleged slow connection on? Just a browser connection? and if so which browser are you using and have you tried something different like maybe Opera)
PostPosted: Thu Jul 21, 2011 2:48 pm
Displayed download rates of a fey BYTES to KB per second.
I decided to plug in directly to the net and it's going fine so far.
I'm going to update everything I can and try Opera and will repost...
PostPosted: Thu Jul 21, 2011 2:59 pm
What did?
PostPosted: Thu Jul 21, 2011 4:11 pm
While updating via system updates.
Also, I separately downloaded chomium, also bytes per second.
After a google search, it seems at least 2-3 other people have this problem as well.
PostPosted: Sun Aug 07, 2011 9:14 am
you say side by side? do you mean Dual boot or what?
PostPosted: Wed Oct 26, 2011 4:12 pm
I see that this is an old post and I hope you have already solved your problem. If not this worked for me just now.
http://www.smachado.com/2010/11/how-to- ... ntu-10-10/
PostPosted: Tue Jan 10, 2012 8:09 am
This post also seems to have solved my issue. Thanks
