It is currently Wed May 22, 2013 4:30 am
 Post subject: New FiOS installation has upload problems, please help
PostPosted: Fri Jun 17, 2011 1:46 pm
Not sure if I should put this in networking forums or not, but the problem seems to be limited to my PC since a hardwired laptop does not have this issue.
I have a hardwired connection to my PC. When I use any speedtest site, my download speeds are about 15.3 mbps which is what we pay for. The upload speed, however, is stuck around 0.4 mbps when it should be about 5.0 mbps. On my mother's laptop, hardwired, her speedtests read 15/5 like they should. My ping is usually around 15ms if that helps at all. Below I have posted the information displayed after using "ipconfig /all" if it is any use to anyone for help me.
So far, I tried switching the ethernet cables, tried different ports on the back of my new router, rebooting the PC, resetting the router, enabling flow control on my onboard LAN port, unchecking QoS Packet Scheduler, booting in safe mode with networking, turning off antivirus and realtime protection (I use ESET), disabling the firewall, accepting all cookies in IE, and reducing as much security options as possible in IE to be as unsafe as possible :roll:. Those are all the things I can remember trying so far.
Any ideas on what might be throttling the upload speeds?
Other info: Mobo: MSI P6N SLI w/ NVIDIA nForce 10/100/1000 Mbps (I checked for latest drivers too)
Intel Core 2 duo
Ask me for any more info that might be relevant!
I get 0.7 upload on my phone while tethering, which is more than the FiOS somehow.
ipconfig /all:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Julien>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Julien-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : home
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : NVIDIA nForce 10/100/1000 Mbps Ethernet
Physical Address. . . . . . . . . : 00-19-DB-6C-E5-C6
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::8486:5777:aa97:89ec%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, June 17, 2011 5:09:08 PM
Lease Expires . . . . . . . . . . : Saturday, June 18, 2011 5:17:19 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 201333211
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-11-12-F5-4E-00-19-DB-6C-E5-C6
DNS Servers . . . . . . . . . . . : 192.168.1.1
71.250.0.12
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 11:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : isatap.home
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 14:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
 Post subject: Re: New FiOS installation has upload problems, please help
PostPosted: Sat Jun 18, 2011 10:48 pm
Fixed the issue by reformatting and upgrading to Windows 7. *shrug*
PostPosted: Mon Jul 11, 2011 4:56 pm
It was probably an issue in the registry or in the TCP stack. There are many settings in Windows under the hood that could have cause that and usually resetting the TCP stack will fix that just in case you see it again.
PostPosted: Tue Jul 12, 2011 2:21 pm
Good to know. Thanks!
