It is currently Tue Jun 18, 2013 10:17 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: MaximumPC Official Star Trek PC Build: "TRICORDER CHIC"
PostPosted: Thu Jun 02, 2011 7:40 am
Mod Edit wrote:
We love seeing your build logs, but please refrain from advertising your services out right. If people like what they see they can use the Google machine to find you.
Mnpctech customizes PCs into unique designs for clients around the world. 10 Year Retrospective of Mnpctech PC Mods
Phenom PC built by Mnpctech for AMD
Mnpctech owner and Pro Modder, Bill Owen
Maximum PC has a presence at Comic-Con every year as an outreach opportunity—to let the hardcore comics and sci-fi fans know that PC enthusiasm goes hand-in-hand with that kind of fandom. This year we’re using our booth as an opportunity to show the fans at Comic-Con how awesome a great case-mod can be and how PC geekery and sci-fi enthusiasm can meet in a beautiful way. So we’ve hired the best guys in the business to design and build an awesome Star Trek-themed PC, and we’ll be giving one away at Comic-Con and the other one will go to David Gerrold in exchange for some writing he’s doing for us in relation to Comic-Con. - Nathan Edwards, Senior Associate Editor
Conceptual Designer: Mike Okuda is graphic designer who has worked on Star Trek series since the 1980s and is responsible for much of its visual style, including the LCARS interface as seen on Next Generation.
Matt Jefferie's original design of the Tricorder served as Mike's inspiration for styling cues on the "Tricorder Shiek" computer case
design. We could have scratch built a PC that looked just like the Tricorder, but David wanted an actual computer case instead with specific utilitarian features like hot swap bays and a compartment for his Tribbles.
3D design of "Tricorder Shiek" by Dave La Lopa of http://www.hivelogix.com
Top panel and storage compartment
Top panel will be milled from 2" thick 6061 aluminum
This Lancool K-58, manufactured by Lian Li will sacrifice it's chassis to this project.
Lancool K-58 chassis will be painted Matte Black Enamel.
Using Rounded side hand file to smooth the cut edges.
Using Red Scotch-Brite pad to scuff the surface in preparation for Primer base coat.
Lancool K58 chassis painted Matte Black Enamel (1 for david, 1 for comic-con)
Machined aluminum computer case feet, http://www.mnpctech.com/ITX_MATX_Computer_Case_Feet.html
Machined aluminum computer case feet with grooved edges.
The aluminum feet are machined on CNC Lathe, http://www.mnpctech.com/ITX_MATX_Computer_Case_Feet.html
The bare aluminum is nice contrast to the Matte Black.
#10 x 5/8" Black Oxide Fan Screws, http://www.mnpctech.com/thumbscrew.html
Screws will be used in conjunction with fan silencing rubber grommets, http://www.mnpctech.com/FanGrommet.html
#10 x 5/8" Black Oxide Fan Screw inserted in rubber grommet
Black PSU and fan wires cable sleeve kit
We are installing Yate Loon Blue LED 140mm cooling fan
Lian Li Tool-Less PCI Card Holder, 7 x PCI Holder. Works with many Lian Li cases or other modified cases. Specifications: Tool-Less PCI Card Holder, 7 x PCI Holder. Designed for Most of Lian Li Cases. Dimension (W)70mm x (H)145mm x (D)30mm
Updated 6/22/11
The first of 2 lower half of the front bezel is finished. Next step is making the upper half and the compartment door covers.
I'll be sleeving the Sentry this Silverstone FP34S Premium 3.5inch Bay Card Reader & Front I/O combo module with our Black PSU and fan wires cable sleeve kit for everything. (8 mil PolyEthylene Terepthalate (PET) monofilament yarns)
Finished the front Hot Swap bay compartment doors last night. These will be hinged with 1/8" rod. The 1/8" Opaque Red acrylic plates will attach to the back side of the door. Still need to make door handles.
Update: 6/24/11
Here is where it's at currently, still need to make upper half of bezel, top panel, front grill, emblem and david's name plate.
Last edited by mnpctech.com on Fri Jul 08, 2011 6:38 am, edited 11 times in total.
 Post subject: Re: MaximumPC Official Star Trek PC Build: "TRICORDER SHEIK"
PostPosted: Thu Jun 02, 2011 9:41 am
Maximum PC Editor
Maximum PC Editor
I'm so excited!
PostPosted: Thu Jun 02, 2011 12:16 pm
Picking up following material list in morning.... 6061 aluminum
1.938 thick x 18.1875 x 8.25 (2 pieces)
1.5 thick x 8.25 x 5.906 (2 pieces)
1.4375 thick x 14.969 x 8.25 (2 pieces)
.4375 thick x 21.25 x 21.125 (4 pieces)
.25 thick 1.625 x .3125 (2 pieces)
.125 thick x 8.875 x 7 (2 pieces)
.125 thick x 20.5 x 20.375 (4 pieces)
.125 thick x 8.578 x 7.5 (2 pieces)
.125 thick x 1.82 x 1.11 (2 pieces)
.125 thick x 8.1875 x 3.219 (2 pieces)
 Post subject: Re: MaximumPC Official Star Trek PC Build: "TRICORDER CHIC"
PostPosted: Fri Jun 03, 2011 1:22 am
Team Member*
Team Member*
That case looks much better already! Its amazing what a coating(or 2) of paint can do. Nice!
Where is the warp core or the dilithium crystals? :)
PostPosted: Fri Jun 03, 2011 2:39 am
Thanks for checking out eh project and commenting Wiked!
I made another fun caption...hehe
PostPosted: Sat Jun 04, 2011 3:25 am
Billet... skid.
I was focused on making a dent in our work load, so I didn't take a lot of photos last night...
First layer is 1/8" thick smoked grey, cast acrylic.
these will 3/16 mounting holes
Starrett spring loaded center punch..
Using counter bore bit to debur holes
Flush.
PostPosted: Sun Jun 05, 2011 2:44 am
This morning I'll be sleeving the Sentry this Silverstone FP34S Premium 3.5inch Bay Card Reader & Front I/O combo module, mainly for it's card reader and headphone jack as per David's request. It's from performance-pcs here It will be mounted in the new top panel. I chose Bulgin's "Orange Dot" for the Main Power button from performance-pcs, here
The Sentry's display screen will be mounted in the top bezel opening. A 22mm Bulgin "Orange Dot" vandal resistant switch will be the Power button.
PostPosted: Sun Jun 05, 2011 8:37 am
Man this is gonna be EPIC. I hope you guys have considered this build for your Second Season of Mod Men! I know its prolly short notice and a lot of work to put together, but it would make a perfect fit.
PostPosted: Sun Jun 05, 2011 11:30 am
Thank you Tobe! I'm recording the progress when I have chance while working on it. The 3.5" HD trays painted Red Enamel and HD cage painted Black Enamel.
another caption by EEL!
PostPosted: Sun Jun 05, 2011 6:40 pm
Team Creamsicles
Team Creamsicles
I want to work for you guys, I live in Iowa. That is all.
lol, fantastic work as always! Getting to do what you love for a living, every man's dream!
PostPosted: Sun Jun 05, 2011 9:43 pm
As much of a geek as I am, and love Star Trek as well, I find this mod to be just... odd. So far the coolest part is the internal color scheme, and the metal expansion card locks. I hope it gets cooler. :?
PostPosted: Mon Jun 06, 2011 2:56 am
Thanks for tuning in and commenting! :D
PostPosted: Mon Jun 06, 2011 12:33 pm
This is definitely going places. Always loved good mods. :)
PostPosted: Mon Jun 06, 2011 3:42 pm
Thanks for checking it out TMc51!
Tonight we'll be milling the aluminum panels and inlay plate for the side panel with the USS Enterprise (NCC-1701) design, which will be slightly larger than whats show in this screenshot.
The top cover will have a compartment...hmm for what?
The compartment lid consists of one sheet of 1/8" thick aluminum and 1/8" Opaque red cast acrylic
PostPosted: Mon Jun 06, 2011 7:57 pm
you're welcome, and here's my pic comment:
PostPosted: Mon Jun 06, 2011 9:31 pm
ok i gotta ask..what machining back ground do you guys have..
obviously it atleast consist of some tool and die.
i know this cuz in my younger days i was an awesome production machinist!
the company's i worked for had several Acme Gridley 6 spindle bar machines,but i am old school..meaning i operate a lathe/mill manually!..lol
ofc i can program anything with a spindle..lol
and yes i have been following your mods for quite awhile..on youtube and on your site :D
PostPosted: Tue Jun 07, 2011 4:34 am
Awesome! Randy has over 40 years experience on variety of manual and automated equipment, including Lathes. He specialized in Mold Making for several years before getting laid off. I found him 3 years ago on Craiglist and have been learning as much as I can from him ever since. Last night the larger aluminum side panel plates took two hours apiece to mill. They exceed the travel space of the mill, so they had to be re-positioned for each side.
Made a temporary Tapping block as guide when manual tapping blind screw holes on backside of the larger aluminum panel.
Blind hole tapped for 8/32 machine screw
Caption by EEL!
PostPosted: Tue Jun 07, 2011 3:09 pm
Sanded edges and removed mill trails on the aluminum panels today.
PostPosted: Wed Jun 08, 2011 5:28 am
USS Enterprise cut in 1/8" thick aluminum exterior plate.
PostPosted: Wed Jun 08, 2011 10:07 am
Finished 1/8" thick Opaque Red acrylic plates in the mill. They will mount inside the machined aluminum exterior plates, as shown in drawing... I'll mount these this afternoon
