It is currently Tue Jun 18, 2013 4:08 pm
 Post subject: Twin GPU Question
PostPosted: Sat Jun 04, 2011 1:42 pm
Can you shut off one core on a dual core gpu? The reason I ask is some games will not run with a dual GPU setup whether or not they are on the same card or two cards. This goes both for SLI and Crossfire.
 Post subject: Re: Twin GPU Question
PostPosted: Sat Jun 04, 2011 2:38 pm
i found this...http://www.overclock.net/amd-ati/1008030-5970-getting-crazy-when-disabling-one.html
some say that you cannot disable the second core on any dual core gpu..regardless if its AMD or Nvidia.
what card do you have that you would want to disable one of the cores?
PostPosted: Sat Jun 04, 2011 2:46 pm
it sounds like more of a hassle than its worth.
PostPosted: Sat Jun 04, 2011 4:35 pm
I was thinking of buying a 6990 to replace my old 5830s.
PostPosted: Sat Jun 04, 2011 4:48 pm
thats great!
good luck getting one from Newegg.cuz their always out of stock,and so is the GTX 590
i guess you can always get 1 from AMD or the likes.
http://shop.amd.com/US/_layouts/shop/shop-amd.aspx?csquery=radeon%206990
