It is currently Wed May 06, 2015 9:42 am
 Post subject: coding PHP and HTML together into one PHP file
PostPosted: Sun May 22, 2011 7:21 pm
I may have asked this a long while back, but need to ask it a gain because I never really saw the result of my question....
Anyway, is there any standard regarding mixing HTML and PHP code in the same PHP file? As in, instead of using ECHO statements to write the HTML code out, is it "safe" to just close out the PHP block, use HTML and then open another PHP code block?
Example:
<?php
//SomePHP
Code ?>
<p>This is a sentence</p>
<?php
//MorePHPCode
--or--
<?php
//PHPCode
echo "<p>This is a sentence</p>";
//MorePHP stuff
Is one way safer than another? I know that PHP just ignores non-php commands.
 Post subject: Re: coding PHP and HTML together into one PHP file
PostPosted: Mon May 23, 2011 2:49 am
That is probably the most common way to do it actually.
PostPosted: Mon May 23, 2011 5:36 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
The first way you mentioned is fine. I might be wrong, but I think you can even have a '?>' mid block and switch to HTML.
PostPosted: Tue May 24, 2011 8:50 am
Go with one that is easiest to debug, that is what I say.
This generally works better:
<? if (isAdmin() == true) { ?>
   <div> This is the admin bar </div>
While this is an oversimplistic example, it's way more readable, and can be debugged easier since you're no longer trying to trace echo outputs.
PostPosted: Tue May 24, 2011 9:15 am
Not to mention performance is probably better...
PostPosted: Mon May 30, 2011 6:22 pm
Alright. Like I said, I'm not into what is the standard and what's not. Obviously, I find that just embedding the <? and ?> tags where I need them is far easier, and just let the PHP processor dump everything else out to the web page...
A long while back, though, I did write a fairly complex page using the first example I gave (where PHP would write all HTML via ECHO commands) and that was a PITA to debug.
