It is currently Sun Mar 29, 2015 3:15 am
Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: TRON PC Case Build
PostPosted: Tue May 24, 2011 11:42 am
Million Club [PC]
Million Club [PC]
Yeah, this build certainly required superior skill to the l3p d3sk mod. Way more custom fabrication too. Bent radiator? That alone tops the desk mod.
PostPosted: Fri May 27, 2011 9:04 am
Well, I'm sitting in 4th place in the vote count with 526. Last day to get your votes in is Sunday! With any luck, I'll score a bit higher on the other aspects the judges look for. Fingers crossed! Thanks everyone for all the support, it was a total blast building this case, and I'm glad you all could join me on this fun modding journey!
PostPosted: Fri May 27, 2011 10:33 am
Million Club - 20 Plus
Just stumbled on the build thread. Voted for your build Bod.
PostPosted: Fri May 27, 2011 2:53 pm
Million Club
Million Club
This is an abosolute inspiration. Great worklog. Thanks for taking the time to share it with us mere mortals we bow at your feet. :)
PostPosted: Sat May 28, 2011 8:28 am
Thanks dedgar & NJdangerous!
I found a few pics that I neglected to post earlier. Here's some shots of the mesh pieces I made for the top. I didn't have a large enough piece to cover the whole length, so I had to do it in two.
I managed to match the hexagon pattern so you can't really tell.
I bent the sides down so it fits snugly in between the two ribs, and I used black zip ties to hold it in place. No time for a more elaborate fastening solution lol.
Here's a shot of the wiring bus I used to connect all the led strips to power.
Some cabling shots. Sleeved ATX, PCI-e, and 12v. You can also see the strings of leds that will be placed around the inside of the window, using velcro.
And some shots of the fairings hanging up after painting.
Assembling...
That's it for now. Next post will probably be an update showing the case at Computex. :)
PostPosted: Tue May 31, 2011 11:31 pm
Took 1st place in the scratch build category!!! :o
http://casemod2011.coolermaster.com/
Thanks all for your support and votes! :mrgreen:
PostPosted: Wed Jun 01, 2011 12:00 am
Awesome bro, glad to hear it! I know I voted for you! :D
PostPosted: Wed Jun 01, 2011 1:43 am
Team Member*
Team Member*
THAT IS AWSOME!!! I am glad that you won, you did more work than that guy with a UV desk.
 Post subject: Re: TRON PC Case Build - 2011 Cooler Master Contest Winner!
PostPosted: Thu Jun 02, 2011 9:56 am
Congratulations :D
Ted
PostPosted: Thu Jun 02, 2011 11:15 am
Fantastic! You earned it.
PostPosted: Thu Jun 02, 2011 7:28 pm
Thanks guys! I really appreciate it.
Found a shot of the TRON case at Computex, featured during Microsoft's press conference today. :)
Good to see it made it there in one piece!
PostPosted: Fri Jun 03, 2011 3:25 am
Definitely a well earned win!
I am still amazed by this one.
PostPosted: Fri Jun 03, 2011 9:45 pm
Here's an excerpt from the Microsoft Forum held the other day, where the TRON case was featured:
Doesnt get much better than that!
PostPosted: Sat Jun 04, 2011 3:22 am
Million Club - 5 Plus
nice.
and you earned it, no doubt about that at all. I still shake my head over that build.
PostPosted: Mon Jun 06, 2011 9:38 am
All hail the Master Modder !!!
Boddaker, that must be the coolest mod coverage I have ever seen !
cant wait to see what you come up with next !
PostPosted: Wed Jun 08, 2011 1:09 pm
Haha, thanks ASPHIAX. Not sure I can top this, but I was working on a new dual-processor graphics workstation build for work before the contest came up, so I'll probably get back on that.
 Post subject: Re: TRON PC Case Build - Monitor Mod
PostPosted: Mon Jul 11, 2011 9:28 pm
Hey guys, finally getting to modding the monitor to match the TRON case. It's still not 100% complete, but it will work for this weekend's LAN party. :)
I designed a new bezel that was cut out of 1/4" blue transparent acrylic. Here I'm preparing to bevel the inside edges.
Of course I neglected to take any pics of the resulting bevel, but you can see it in the last pic.
To fasten the screen, I'm re-purposing these special hard drive mounting screws that have built-in washers. I just had to cut the length down since the threaded holes aren't very deep.
Here's one side with the mounting flange glued to the bezel, and the monitor mounted to it.
For the back side, I had to make a cover that would hide the two circuit boards. After extensive measuring of the LCD's backside, I made up a sketchup model to get the angles correct, then took measurements off that to draw up the cut file. Pieces were cut from 1/8" black acrylic.
I added some venting on the top piece, TRON style. (also putting my brass MNPC-Tech modding ruler to proper use :D)
Here's a shot of the underside, after gluing the pieces together.
Gluing the monitor supports on...
I went with some arbitrary angle sharper than 90 degrees on the supports, and ended up being close to an ergonomically correct viewing angle.
The bezel with the monitor installed.
and a back shot. Funny, the camera angle makes it look like the right support is missing lol.
I still have plans to add lighting and paint, but that will have to wait 'til after the LAN.
PostPosted: Mon Jul 11, 2011 11:37 pm
So u took badass and made it even more so, awesome.
PostPosted: Sun Aug 21, 2011 12:45 pm
When will we see an update? Man I wish I would have gone to the last PDX. I REALLY wanted to see the Tron Bike mod.
PostPosted: Tue Sep 06, 2011 9:13 pm
a pic from the lan, on page 42, latest CPU magazine (october) http://www.computerpoweruser.com/DigitalEditions/Archive.aspx
