It is currently Tue Mar 31, 2015 2:19 am
Post new topic Reply to topic  [ 592 posts ]  Go to page Previous  1 ... 25, 26, 27, 28, 29, 30  Next
 Post subject: Re: CPU speed brag time!
PostPosted: Mon Nov 15, 2010 1:46 pm
Million Club
Million Club
I don't miss the old ways of overclocking at all, but I do like the bios overclockinh tools more than the remote, auto, and application based overclocking tools.
:mrgreen:
PostPosted: Tue Nov 30, 2010 11:47 am
Clock2theMax wrote:
I miss dip switches, old school overclocking...long time no see, my old comrades, 5 years since my last login :P
Welcome back, old man.
Gonna stick around for a while?
PostPosted: Thu Dec 02, 2010 9:02 am
As I stated in a recent post, I'm running my E8400 At 4.16GHz. Not too shabby. But RAM is getting in the way sometimes, and I'm at the minimum 1:1 ratio between RAM and FSB, so about 920MHz on the RAM.
With 2 sticks of RAM, I was able to hit about the 4.3ish mark, but i don't like hitting 75-76C in Prime95. 'Twas nice testing the RAM at 1200MHz, tho. not the mostt stable, but that stuff was plowing through benchmarks. Settled at 1128MHz. Then got 2 more sticks. Each set separately runs at that, but together, I'm hard pressed to hit 920-940 any more.
PostPosted: Fri Dec 10, 2010 1:22 am
[Center]4.0GHz
http://www.youtube.com/watch?v=VUKqHjIQD4Y
4.0GHz continued
http://www.youtube.com/watch?v=xPQiGWxaz1k
[center][URL="http://valid.canardpc.com/show_oc.php?id=1523758"]4.2GHz Validation!!!!!
Image[/URL]
4.2GHz!!!!
http://www.youtube.com/watch?v=hCNtRGm7-iQ[/center]
4.3GHz <--- FAILED D:
http://www.youtube.com/watch?v=lRCFjfUXIgc[/CENTER]
Some benches @ 4.0GHz - 1100/1350!
3Dmark 11 (did a oops here and ran Extreme Oh well XD)
[url="http://3dmark.com/3dm11/28020"]X1816[/url]
3DMark Vantage
[url="http://3dmark.com/3dmv/2781144"]P15855[/url]
3DMark 06
[url="http://3dmark.com/3dm06/15129152"]19432[/url]
PostPosted: Sat Dec 11, 2010 8:25 am
Million Club
Million Club
Time to update my OC info, since my Foxconn Destroyer got here:
And the temps while Prime95 ran in the background (I have gotten them under 60c since then):
AND, my Non-Extreme Edition Pentium 4 is now running at 3.92ghz (up from 3.2ghz stock):
CPU-Z Valid
I have the temps under 50c all the time (Idle or Load, both stay under 50c,
and often under 40c) using only a high-flow case and a Zalman CNPS 7700CU.
Working on the RAM, but will get some high-performance DANK for it soon. :P
PostPosted: Wed Jan 12, 2011 11:11 pm
Not a bad first crack, with a Hyper 212+ on it, runs about 85 degrees C according to SpeedFan under full load.....
http://valid.canardpc.com/show_oc.php?id=1591788
Edit, with a H70 sitting on top of the i7, 80 degrees at 4Ghz....quite nice
http://valid.canardpc.com/show_oc.php?id=1696237
 Post subject: Aktualisiert!
PostPosted: Mon Jan 24, 2011 8:37 pm
Million Club
Million Club
Now that my Phenom II x4 965 Black Edition
has arrived, the OC has been applied:
VALID
Idle TMP: 40°c (Usage at 2% or Lower)
Load TMP: 58°c (Prime95 / F@H)
Ambient TMP: 42°c (7 Case Fans)
Cooling: CM Hyper212+ (Single Fan, Pushing)
PostPosted: Thu Mar 24, 2011 1:29 pm
Team Member*
Team Member*
Just got my hyper 212+ on and have done a modest overclock on a 2500K running on a P8P67 Deluxe hit 4.8GHz from 3.3GHz not bad on air so far temps hitting 81C but I will continue to break it in. Image http://valid.canardpc.com/show_oc.php?id=1729643
PostPosted: Sun Apr 10, 2011 6:12 pm
Team Dino
Team Dino
My first real attempt at overclocking my 2600K: 4.6 GHz.
n0b0dykn0ws
PostPosted: Sun Apr 10, 2011 10:02 pm
Nicely done, n0b0dy.
PostPosted: Mon Apr 11, 2011 2:58 pm
Team Dino
Team Dino
Well, after I got home from work this afternoon I found my system blue screened.
I tried upping the voltage a little but continual blue screens.
Had to put it back down to 4.5 GHz.
n0b0dykn0ws
PostPosted: Tue Apr 19, 2011 2:14 pm
Million Club
Million Club
2500K & 212+ : 4.5ghz (x45, 100blk) 57C max
4.7ghz (x45, 105blk) 66C max
PostPosted: Tue May 03, 2011 6:25 pm
Phenom II 555 BE 3.2 GHz @ 4.2 GHz on air...haven't run Prime95 or anything on it yet though.
Edit: N/M, had to bump the multiplier back down a notch, it just blue-screened.
PostPosted: Fri May 13, 2011 2:50 pm
Team Dino
Team Dino
4.7 GHz stable.
n0b0dykn0ws
PostPosted: Thu May 19, 2011 4:22 pm
Million Club
Million Club
CPU: AMD Phenom II x4 965 BE C3
Base Freq: 3400mhz
Overclocked: 4500mhz
Cooling: Hyper212 w/ 2x Scythe Ultra Kaze Push/Pull.
Idle Temp: 33c
Load Temp: 55c
Prime95/F@H Stable.
CPU-Z Dump
PostPosted: Thu May 19, 2011 10:38 pm
Team Dino
Team Dino
Jake, what's the PPD on that?
I have an AM2+ board that can handle the high watt quad core AM3s, and I might give it one last boost.
n0b0dykn0ws
PostPosted: Wed May 25, 2011 10:53 pm
Million Club - 10 Plus
EDIT: upped from 4.65 to 4.7
PostPosted: Sat Jun 18, 2011 7:13 pm
Million Club
Million Club
n0b0dykn0ws
Sorry it took me FOREVER to get back in here and post, but I have been busy as hell of late.
The PPD is 9,500+ PPD @ 4ghz (4.5ghz on air in southern NM is not advisable and I had to back
off, even with an H70. I will need a full-on loop). But I am about to up the ante because I got
the chip stable at 4.2ghz on air. It is cooking in Prime95 now... 1.5 hours stable. I have heard
that even at just 4ghz, if you run the SMP in a virtual machine, you can push PPD to about 10~12k
PPD! I will try it out and see. Plus, HFM can still track the PPD and TPF for you and spit out the
results into an HTML page which I have synched to my dropbox as a public document like this.
And that's awesome. :P
At any rate, here is my new Validation for SMP-Stable 4.2ghz:
PostPosted: Sat Jun 18, 2011 9:43 pm
Here we go. Stable on air, but too damn hot to fold on 24/7, but who cares, this is bragging rights, isn't it?. :)
PostPosted: Sun Jun 19, 2011 4:57 pm
here's mine..it aint on air,but ohwell.
http://valid.canardpc.com/show_oc.php?id=1876505
