It is currently Wed Jun 19, 2013 6:40 am
 Post subject: Backing up saved games?
PostPosted: Sat May 14, 2011 10:26 pm
I'm having issues with Portal 2 locking up and going back to the desktop with "Portal2.exe has stopped working" so I want to uninstall the game and re-install but don't want to loose my saved game. Is it as simple as copying the save folder and pasting it into the re-installed game folder?
or
If you guys have a fix to this issue that would be awesome as well. And yes drivers are the latest, tried to "fix" or "validate" the game, updated steam (which I think is the culprit because it worked fine before this), uninstalled steam and re-installed, checked firewall, ect.
 Post subject: Re: Backing up saved games?
PostPosted: Sun May 15, 2011 7:57 am
Look in the Event Viewer for errors in the system and application logs.This is a good place to start the diagnostics of the system.
PostPosted: Sun May 15, 2011 11:35 am
just check where the games are saved at, many of mine (farcry2 for example) are saved in windows files not in the game itself, and will still be there with a reinstall.
if you reinstall over the old game, the saved games (if saved in the game itself) should still be there.
i have reinstalled both of the mass effect games from steam and my saved games are still there.
PostPosted: Mon May 16, 2011 9:55 pm
P2 saves aren't put on the cloud so you'll have to back them up. Find you steam folder and go Steamapps -> Common -> Portal 2 -> Portal2 -> SAVES
Back up the SAVES folder and uninstall and reinstall Portal 2, then drop it back in place.
PostPosted: Tue May 17, 2011 6:41 pm
Steam actually has a feature that allows you to backup your games, just look in the mini-menu of options, I think it's called "Bacup and restore game data" or something to that effect. You get to choose what to backup, where to and in what capacity manner.
PostPosted: Wed May 18, 2011 12:18 pm
IIRC that option backs up the downloaded game, but not your game saves. If you restore let's say Dragon Age Origins with one of these back ups you'll find you have your game installed but without any of your characters
PostPosted: Wed May 18, 2011 9:05 pm
All my steam games had my saved profiles and settings.
PostPosted: Wed May 25, 2011 12:10 pm
Cool, I have to try it later... but I've been so lazy that I haven't put my PC inside my new Corsair 800D case... I guess I'll just take your word :P
