skivskiv wrote:
Well, ready or not I'm taking the A+ Essentials (220-701) this Saturday at 1:00PM.
So, if anyone has any advice on the 2009 exams, I would be eternally grateful.
How did you do? It wasn't so bad, was it? I never felt like I needed A+, but I'll probably take it before they
start to expire. hackman2007 wrote:
I have taken the 2006 objectives and yes they try to trick you. The trick is to not read more into the question than what is given.
Newer Comptia exams are fairly straight forward. I have my Network+ (2009 Edition) and Security+ (2008 Edition). There's usually a couple off the wall questions, but I never felt like they tried to trick me. The
process of elimination always helps when we don't know the answer. Wish I could say the same for ITIL tests.
CompTIA has great
Practice Questions on their site, and they're exactly what we can expect to see on the tests.
http://www.comptia.org/certifications/t ... /a701.aspx
http://www.comptia.org/certifications/t ... /a702.aspx
http://www.comptia.org/certifications/t ... twork.aspx
http://www.comptia.org/certifications/t ... urity.aspx
