It is currently Wed Mar 04, 2015 6:36 pm
 Post subject: Help!!! PSU wont fit!!?!
PostPosted: Sun Apr 10, 2011 11:04 am
I bought a corsair 700w psu, and tried it on my antec sonata 3 case, but the screw holes dont match up, the corsair is a bit bigger than the stock 500watt that came with the case, and I rlly need help looking for a 700 watt that will definitely fit in my mid tower case. I have a asus m3n78 pro mobo(if that helps)
 Post subject: Re: Help!!! PSU wont fit!!?!
PostPosted: Tue Apr 12, 2011 11:08 pm
Team Member*
Team Member*
What is the model number of the PSU?
What is the model number of the Case?
Maybe with the model numbers we can figure out what is up it seems odd that it won't fit but there are those odd occasions when stuff goes wrong in the planning phase.
PostPosted: Wed Apr 13, 2011 8:07 am
Million Club - 10 Plus
Try turning the PSU over... That might solve your problem.
PostPosted: Thu Apr 21, 2011 11:05 pm
That was also MY first thought, lol.
