It is currently Wed May 22, 2013 2:45 am
 Post subject: Proxy/Cache VM server?
PostPosted: Sat Mar 19, 2011 8:38 pm
Team Dino
Team Dino
Is there a quasi pre-configured proxy/web cache virtual machine out there that's trustworthy?
If not does someone here have vast experience setting one up from scratch?
n0b0dykn0ws
 Post subject: Re: Proxy/Cache VM server?
PostPosted: Sun Mar 20, 2011 6:55 pm
No to both.
Are you looking for a VM set up?
This help?
http://www.vmware.com/appliances/directory/
PostPosted: Sun Mar 20, 2011 7:02 pm
Team Dino
Team Dino
I would either run VM Player or VirtualBox.
I just still have few skills navigating around in Linux. :oops: Especially deep inside config files.
That's why I was looking for something I could edit minimally, and would be easy to run inside VBox with attached USB storage.
With storage being as cheap as it is, and AT&T implementing a cap in the near future, I figure running a cache server for MS and Norton AV updates would help save some bytes.
*EDIT* I looked at your link, and tried searching for cache proxy, and the only one that seemed to do what I want had no real notes/documentation.
I should also add that Anandtech had a pretty good how-to on it, so if I have more than enough time to fidget around I could possibly get it working myself. */EDIT*
n0b0dykn0ws
PostPosted: Mon Mar 21, 2011 4:19 am
AT&T DSL?
PostPosted: Mon Mar 21, 2011 5:42 am
Team Dino
Team Dino
Yes. Even though it's a 150 GB cap, my wife watches a lot of Netflix streams and uses her Android phone almost exclusively on WiFi.
Add on top of that the 5 computers in the house that receive daily AV defs, and it all starts adding up.
What's worse is at work most XP drivers are blocked due to a lack of a digital signature. This wouldn't be so bad if some of my systems weren't custom. So often I find myself remoting into home, downloading the drivers there, and copying them over the network here to work. Just so I can do my job.
Like I said, creating a cache proxy will alleviate only a little, but that's better than nothing.
n0b0dykn0ws
