It is currently Mon Apr 27, 2015 9:22 am
 Post subject: Android Programming Book
PostPosted: Mon Mar 14, 2011 10:19 pm
Hi all,
I'm looking to learn the android SDK and UI layout, does anyone know any good books out for that? I already know Java so I don't need a book that will teach me that again, but I know nothing about Android programming
Thanks!
 Post subject: Re: Android Programming Book
PostPosted: Wed Mar 16, 2011 4:01 am
legacy2013 wrote:
Hi all,
Thanks!
I use this. Tell me if you like it. :D
PostPosted: Wed Mar 16, 2011 5:39 pm
I actually have looked at that before but the App I am looking to write is more advanced than what that will allow. I can program in java, as well as other languages, very well so coding shouldn't an issue I just need to learn
PostPosted: Sat Mar 19, 2011 6:17 am
The android app platform is Java, so you should be ready to go minus minor references to the web. No sense in buying a book about it. Just down load the developer kit and get started!
PostPosted: Wed Apr 20, 2011 1:55 pm
I don't know if you've seen this but I started here with the tutorials and found them to be quite useful in learning how to develop Android apps. There is an excellent android development plugin for the eclipse IDE that is discussed in the tutorials. Hope this helps.
PostPosted: Thu Aug 11, 2011 4:08 am
From where i find a printed handed book for Android Programming??
