It is currently Mon May 20, 2013 4:32 am
 Post subject: Blue Dots distortion in Blu-Ray
PostPosted: Thu Mar 10, 2011 9:03 am
I recently purchased and installed an XFX 6850 in my home theater PC. Everything seemed to be okay, but when I popped in a Blu-Ray for testing, some of the previews were just green screens, but I could still hear the audio. I have watched this BD before, so I know it’s not the disk.
After passing the previews and getting to the menu, I select play and it does. The problem is when it gets to black scenes I see blue dots in the blackness. I was watching Wall-E and the beginning starts in space. So a lot of blackness. One weird thing I noticed. Even the black bars at the top and bottom of the screen have blue dots in them. At first I thought this was only affecting the Blu-Ray movies. However I watched an episode of House and I noticed them in very dark portions of the screen.
I have the HTPC going via HDMI to my Onkio 7.1 receiver then via HDMI to my TV. I have NEVER noticed these black lines in the other HDMI content I watch. Comcast cable, Samsung DVD player, XBOX 360, even another PC with an onboard Radeon HDMI.
Do I have a bad card? Is this a known problem? Should I just return it, and go back to nVidia?
HTPC is:
XFX 6850 w/ Latest Catalyst drivers
Windows 7 Ult. x64
Asus P5Q Pro
Intel q9550
Happauge Tuners x3
ATI Tuner PCIe
Seagate hard drives x9
Intel SSD G1 80GB
3Ware SATA RAID Controller 9650
 Post subject: Re: Blue Dots distortion in Blu-Ray
PostPosted: Thu Mar 10, 2011 9:18 am
Team Dino
Team Dino
What software are you using?
I've seen similar color problems on my Radeon HD 5670, and usually a reboot solves the issue.
I'm guessing it's the Catalyst drivers.
n0b0dykn0ws
PostPosted: Thu Mar 10, 2011 12:01 pm
I am using Cyberlink Power DVD 9 Ultimate version. and Snapstream's Beyond TV 4.9. It happens in both.
PostPosted: Thu Mar 10, 2011 12:50 pm
Team Dino
Team Dino
Have you had a chance to try rebooting?
n0b0dykn0ws
PostPosted: Thu Mar 10, 2011 1:55 pm
Yes I have rebooted several times.
PostPosted: Fri Mar 11, 2011 7:15 am
Team Dino
Team Dino
Did you make any Catalyst changes prior to this happening?
What was your previous card?
n0b0dykn0ws
PostPosted: Fri Mar 11, 2011 7:33 am
Thanks for the replies.
When I first say the blue dot issue it was just after installing the 6850. I had made no changes other then initially installing the drivers and rebooting. My old card was a nVidia 9600GT. However I had problems with that card outputting to HDMI, I could not get the sound through it. So I used a ASUS Xonar DX card to output 7.1 to the Onkio, and used the 9600GT's VGA output directly to the TV.
I tried again to watch a Blu-Ray. At first it seemed fine, but after a few minutes it was showing the dots in the blacks.
Matt|ttaM
PostPosted: Fri Mar 11, 2011 7:43 am
Team Dino
Team Dino
Are you still running through the Xonar or are you going straight from the 6850 to the receiver?
Also, have you uninstalled all old drivers that are no longer needed?
I use a program called REVO Uninstaller. (The freeware version works just fine.)
Make sure you remove all nVidia drivers.
If you're still getting blue dots, try the HDMI connection to a different input on the Onkyo receiver.
If you're still having issues I have one or two more things to try.
n0b0dykn0ws
