It is currently Thu Mar 05, 2015 12:25 pm
 Post subject: Diablo 2 and nVIdia drivers.
PostPosted: Sat Feb 26, 2011 5:41 pm
Team Dino
Team Dino
I'm trying to play Diablo 2. I have a GeForce 260 GTX, which works fine with other games.
I try playing D2 using D3D and it stutters.
Anyone else still playing D2 using a nVIdia card? If so, which drivers are you using?
n0b0dykn0ws
 Post subject: Re: Diablo 2 and nVIdia drivers.
PostPosted: Sun Feb 27, 2011 4:37 pm
You may have to set up a profile for the game and slow down video acceleration.
PostPosted: Tue Mar 01, 2011 10:06 am
Moderator
Moderator
I have a GTX 280 Superclocked and can play D2 fine. I'll check what drivers I'm running when I get home.
PostPosted: Thu Mar 03, 2011 2:03 pm
8800 GT using drivers from july 2010 no problems. Your machine is almost certainly powerful enough to use the software renderer. Have you tried that?
PostPosted: Fri Mar 04, 2011 6:48 am
Team Dino
Team Dino
Yes, but for some reason it takes approximately 20 minutes from the time I open the shortcut for the game to start under software mode.
n0b0dykn0ws
PostPosted: Fri Mar 04, 2011 9:06 am
It may be the cpu and not the video card that is causing the problem. Right click the .exe and set the affinity to one cpu core and run the game.
PostPosted: Sun Nov 13, 2011 11:16 am
or it may be the sound card .. currently i am useing onboard sound and hav e no problems at all win 7 64 bit and nvidia gtx 560 ti
but on my previous rig i ahd issues i had a creative sound card .. win vista and later upgraded to win 7 32 bit i had an issue with a creative thing it was a i dont even know what they call it where it did some sort of emulation for windows
