It is currently Mon Jan 26, 2015 7:28 pm
 Post subject: I am stumped.
PostPosted: Mon Feb 07, 2011 1:46 am
My motherboard supports Gigabit. (Asus Sabertooth 55i) Just bought a new router and I KNOW it does wndr 3700. Replaced my old cables that didn't support gigabit with new Cat 6.
However when I look at my options I am still left with a 100mb connection.
 Post subject: Re: I am stumped.
PostPosted: Mon Feb 07, 2011 9:31 am
Where are you looking at your options?
PostPosted: Tue Feb 08, 2011 1:34 am
I was actually kind of hoping that you all could help me with the options, not even sure where to look. Drivers are up to date on the realtek device, motherboard and as for my router it has the most up to date firmware. Like I said I replaced my Cat5 cables with Cat6 that actually support gigabit. I am at a loss, thus being stumped.
PostPosted: Tue Feb 08, 2011 7:02 am
I was actually kind of hoping that you could at least answer this. Obviously you're looking at something.
Ya know what...forget it...have you looked at the network card properties either through the device manager or elsewhere and looked at the dropdown for eithe connection type or media type? The drop down should at least list 1000 BaseT (or something to that effect)
PostPosted: Tue Feb 08, 2011 12:15 pm
You should be able to verify the connection speed by viewing the Router statistics (see page 65 of the User Guide). I assume your CAT6 cable goes directly from your computer to your router and you are not using a switch or hub in between. You mentioned a single device (your computer) that is capable of gigabit speed but without another device on your network that is also capable of gigabit speeds this is all a moot point since your internet connection cannot take advantage of that speed. So what are the other gigabit devices?
PostPosted: Thu Feb 10, 2011 7:16 am
You're right, I cannot take full advantage of gigabit. I would say, 300mb/s would suffice. I pay for about 35mbp/s down. In the router it says I am running 100MBp/s while my gigabit switch is running gigabit. And when I plug my ethernet cable into the switch, I am still at 100. It has to be my motherboard, but when I had my dlink hooked up it was gigabit.
