It is currently Thu May 23, 2013 6:42 pm
 Post subject: Migrating a Win 7 install to another drive
PostPosted: Mon Jan 10, 2011 10:14 am
Hey all,
Been out of the loop regards moving an OS from one drive to another and will appreciate a refresher... thx ! :)
 Post subject: Re: Migrating a Win 7 install to another drive
PostPosted: Mon Jan 10, 2011 1:39 pm
i just did this with my wife's and my pc
using hdclone
I got new hd for xmas and so the mrs got my old one to replace the asstastic one she had (maxtor 120GB IDE drive...bleh.) I got a hitachi 1TB drive (sata) and she now has my old hitachi 500GB (sata)
the UBCD has the free (slow // limited) version of HDclone and some other cloning tools I've not used so can't say how good or not good they are. I am going to try PING I think at some point but haven't had a chance yet. I've used trueimage in the past and it is fine also.
I can say with absolute certainly the HDclone worked without problems for both of my recent hd migrations and has worked for other migrations without difficulties in the past.
PostPosted: Mon Jan 10, 2011 5:53 pm
Malware specialist
Malware specialist
CopyWipe is also a great option that is included with the UBCD. It is much faster than HDClone and also supports USB drives.
However, it is in a DOS-based window rather than full GUI. It is easy to understand though.
PostPosted: Mon Jan 10, 2011 11:24 pm
There's a good thread on the other side of this board same subject.
viewtopic.php?f=36&t=110721
PostPosted: Wed Jan 12, 2011 10:34 am
I have a copy of Norton Ghost 2003... Think it'll work?
I suppose I should also throw in a wrinkle.
I have what I take is an older board that support SATA and not SATS2.
My WIN7 install sits on a WD Raptor RAID 0 config - supported by the MOBO (not a stand alone RAID card).
Plan is to migrate this install to a SSD which is an SATA2 - thought I read in the magazine SATA2 was backward compatible so that using it on a SATA board would be OK.
I know my copy of WINXP requires drivers to use the RAID config but am assuming since the BIOS supports the RAID config naitively, that when I fire up whatever DOS tool to do the migration, I shouldn't run into any problems.
But....
PostPosted: Wed Jan 12, 2011 12:15 pm
So why did I install WIN 7 on a RAID 0?
Well, was just playing around with the OS and wasn't ready to make the switch to using as a primary.
And since the RAID 0 gave me maximum speed (since it sat on a pair of Raptors), seemed like a fun thing to do : )
One thing that keep me from seriously considering WIN 7 was the migration of my iTunes library.
Seemed to take a while figuring out how I'd proceed WITHOUT:
- having to reload my iPod
- losing my play counts!
That barrier licked, I think I'm ready to reply on WIN 7 now but of course, don't want to reply on a OS that is considerably more fragile than my XP install since it sits on two HD's...
PostPosted: Wed Jan 12, 2011 12:19 pm
btw, this seems like a pretty good deal on a 128gig SSD: Kingston 128GB SSDNow V Series SATA 2.5" Solid State Drive (SSD) $144.95 shipped AR at Buy.com
PostPosted: Thu Jan 13, 2011 6:32 am
I'll be waiting for another 6+ months to get an SSD for my laptop. It will SCREAM when I do though. :)
I am thinking about installing Win 7 to a CF card to run a media center box on.
PostPosted: Sat Jan 15, 2011 8:26 am
I contacted KINGSTON and they provided me a free copy of ACRONIS - resolved!!!
Still need to rig my boot menu to look at the new drive for the WIN 7 install... that can be done using the WIN 7 install disk?
PostPosted: Sat Jan 15, 2011 9:06 am
UPDATE: my WIN 7 install is now running on my SSD and yeah, i'm stoked : )
