It is currently Tue Apr 21, 2015 3:27 pm
 Post subject: DNS Help
PostPosted: Mon Dec 06, 2010 8:33 am
Please help a networking noob.
I have a Linksys WR54GL router running the standard (latest) firmware. I would like to update my DNS service to Google's like the latest MPC showed us. But for the life of me I can't find the appropriate spot in the routers menu.
Can someone point it out to me please.
Thanks.
 Post subject: Re: DNS Help
PostPosted: Mon Dec 06, 2010 8:22 pm
Million Club [PC]*
Million Club [PC]*
Unless Linksys has made some crazy change to hide / move this (I'm looking at the online emulator for it - no more Linksys router here...)
Setup > Basic setup. In the Network Setup section, you enter the DNS server addresses as part of the DHCP server config.
HTH
PostPosted: Wed Dec 08, 2010 8:01 pm
yea...this is a DHCP deal...
you're not going to be able to tell the WAN side of things which DNS to use unless you're paying for a specific type of service from your ISP where you can do that (i.e. static IP), so you just need to tell your machines what DNS you want them to use. Alternatively, you could just manually configure the DNS at each machine, at which point it won't matter what DHCP tries to hand out
PostPosted: Sun Dec 12, 2010 10:00 pm
I can set a static DNS from my Linksys router, and should be able to regardless. But yeah, alternatively, you can set it manually on each NIC and it will use that instead.
